Old 02-26-2009, 02:49 PM
jprh jprh is offline
Angry Hydraulic Clutch on EC 250 not engaging
I have bled the clutch 4 times using the 'syringe technique' and the clutch refuses to engage. When pulling on the clutch lever I can hear that there is movement in the in the gearbox, however no gear engages as the clutch is not releasing.
Old 02-26-2009, 10:11 PM
gasit16 gasit16 is offline
Make sure the plates are not stuck.
Old 03-01-2009, 05:54 AM
Post gasit16
Before i read your feedback my brain decided to work, i realised that might be the only thing it could be?Well i,ll be f*#*ed they were (as you said)all stuck together,the rest is history and the gasser ripped up the track before it developed what i hope is a fuel problem .Throttle open and a starvin sound whoop whoooop whooooop,Thanks for your help anyway you were 100% right
Odd clutch hydraulic behavior AZRickD Enduro Engine - 2 stroke 18 10-22-2008 06:47 PM
HELP! - bleeding hydraulic clutch SpeedyManiac Enduro Engine - 2 stroke 6 10-10-2008 07:12 AM
Hydraulic Clutch Oil?? jyellard Enduro Chassis & Body 10 10-01-2008 01:34 AM
Hydraulic Fluid for the clutch lukachuki Enduro Engine - 2 stroke 2 09-22-2007 05:59 PM
