EC 300 2014 marzochi 48 bushings
Hi,
Can some one point me where i can get busshings for this fork? i check allballs but they only have the oil seals, maybe a set from other suspenssion will do? thanks |
InnTeck makes suitable bushings. I have used them in my PFP 48 fork.
https://www.innteck-usa.com/products...roductID=22919 https://www.innteck-usa.com/products...roductID=22904 I'm getting ready to do mine so I would like to make sure I'm ordering the correct ones.
I have a genuine set brand new here. Can't remember what I paid for em, but more than I would have for KYB.
I don't need em anymore.. |
I also used SKF seals #KITG-48M (seal and wiper kit) And in case you need the tools to do the job: -Motion Pro Fork Compression Valve Removal Tool - 08-0373 -Motion Pro 49mm Dual Chamber Fork Cap Wrench - 08-0429 -Motion Pro Ringer Fork Seal Driver 48mm
2021 Beta 300RR 2014 Gasgas XC300R 2019 850 Pro RMK |
https://www.allballsracing.com/38-6068.html https://www.allballsracing.com/55-132.html i selected on their website the parts for a 2013 YZ250, also i put those kits on mine EC 300 2018 KYB. The suspension became very plush after the rebuild, love it. also i put less 25cl less oil. Edit: i dont have access to innteck components in Portugal. |
The KYB allballs kit will fit the Marzocchi 48, bushings and oil seals, i checked this website description that is bushings for a Marzocchi 48:
https://www.extracross.com/Suspensio...ml?language=en https://www.extracross.com/Suspensio...nner-tube.html I checked out the measures they give in the description and they are the same measures as the ones that cames in allballs kit. |
I had remembered someone saying the bushings do crossover to I thought a Showa fork but can't find the info now.
You have listed one KYB part and one Showa part. You're saying both come in a KYB kit? I know the KYB seals fit as I have them in my Zoke 48's but neither KYB nor Showa dust seals fit that I could find. Please elaborate a bit more as it would sure make getting parts easier!
https://www.extracross.com/Suspensio...ml?language=en https://www.extracross.com/Suspensio...nner-tube.html This bushing sizes are the same as the ones that came in my allballs kit for a KYB forck, the oil seal is the same also, as for the dust cover i don't know because we are keeping the old one. but i can check that for you. Cheers. |
48 cc marzochi revalve help | rvktm | Enduro Suspension | 5 | 08-20-2018 03:39 PM |
Looking at a set of Marzochi 48mm with GG triple clamps | GGRider01 | Enduro Suspension | 3 | 11-06-2015 06:59 PM |
50mm Marzochi fork oil level | PEB | Enduro Suspension | 0 | 03-09-2014 05:24 PM |
2000 wp/marzochi/ohlins/sachs/etc. etc | mikevancapel | Enduro Suspension | 8 | 01-01-2012 08:21 AM |
