2001 GG 200 endro
I got a deal on a 2001 Gas Gas 200 endro. Here is the the problem the motor is locked up. looking for either a place to buy parts or a used motor
Oh yea I will need some plactics too. How hard would it be to turn it into a supermotar? Ok so I found out I have a xc200 not an endro. My bad...... Last edited by lvnspeed; 01-15-2009 at 07:51 AM. |
Ive got a brand new cylinder and piston if your interested
How much shipping to Birmingham AL 35209 USA?
200 top end
pm sent re jug
Before you get carried away with a full blown rebuilt, pull the top end and see if a "crank stuff" bolt worked it's way out and is jamed between the rod and crank. Then go from there...
Rick 99 EC 200 06 RM 250 AMA D36 375X OTHG 375S ***Thanks for the support : Twin Air /O'Neil Racing / Race 100% / Matrix Concepts / ODI / Mika Metals |
Thanks I am going to take it apart tonight.
Ok I got it apart tonight and there is nothing wrong with the top end THANKS RICK
Where is the bolt your taking about? Cranks stuff bolt????? |
HTML Code:
lvnspeed Ok I got it apart tonight and there is nothing wrong with the top end THANKS RICK Where is the bolt your taking about? Cranks stuff bolt????? IMG_2313-3.JPG |
I did see anything wedged in the crank/case. I will keep looking tonight I am going to pull the side covers off maybe something in there.
Found the problem a crank bearing was going away.
a couple of questions: Should I have the whole crank rebuilt? Who can do it? Are there gasket/seal/oring kits Any parts layouts? When I split the cases a couple of thing fell out and I an not sure where they go |
2001 Ec 300 | forgiven | Enduro Engine - 2 stroke | 4 | 12-16-2009 01:24 AM |
purchasing 2001 ec 300 - what to look for | krazy | General Discussions & Announcements | 3 | 06-15-2008 07:42 PM |
2001 Ec 250 | Madmostin | Ride Reports | 0 | 07-08-2007 06:21 PM |
