cooling pump shaft
gday fellow gasers ,i own an 06 ec300 and the cooling pump shaft has brocken in two ,has anyone else had this problem ,i am at a loss as to how it has happened
minds are like parachutes.....they only function when open |
Thats a new one. Even if the bearing seized I would think the gear would break first. Post a photo of the broken parts I would be interested to see them.
as you can see in the photo it has snaped were the locating pin goes. also you can see how the counter weight has come into contact with the plastic gear.
when the shaft is in one peice the gear cant! come into contact with the counter weight so the shaft must have broken first then the gear has moved back and come into contact with the counter weight (this is my therory) so how did the shaft break its not under any load the impeller has no marks on it to sugest that it may have been jamed. i hav orderd the parts and there very inexpensive but i dont want it to happen again.
You are absolutely right. I'd say the shaft was damaged when the pin was pressed in. This is a very, very rare case. I'd put it back together and not worry about it.
lufc
My 06 de300 did the exact same thing, except when my shaft broke it took out the internal water pump bearing as well. |
sprocket how do you reckon it happened ,i am thinking that the bearing has worked its way out of the seating which has allowed the shaft to move around and eventually snap
oil in cooling water | Klausen | Enduro Engine - 2 stroke | 10 | 08-06-2011 09:35 PM |
Transnission shift shaft. | Trailrider | Enduro Engine - 2 stroke | 15 | 02-28-2010 05:10 PM |
Balance shaft removal. | darren | Enduro Engine - 2 stroke | 3 | 11-15-2009 05:18 PM |
help and advice please 400 output shaft | Paul Somerville | Enduro Engine 4 stroke (including EFI & Exhaust) | 0 | 11-01-2009 03:14 AM |
pv actuator shaft broken help plz | fullthrottle | Enduro Engine - 2 stroke | 0 | 07-26-2008 12:46 AM |
