Old 05-20-2007, 11:30 PM
lufc lufc is offline
Default cooling pump shaft
gday fellow gasers ,i own an 06 ec300 and the cooling pump shaft has brocken in two ,has anyone else had this problem ,i am at a loss as to how it has happened
minds are like parachutes.....they only function when open
Old 05-21-2007, 05:51 AM
GMP GMP is online now
Thats a new one. Even if the bearing seized I would think the gear would break first. Post a photo of the broken parts I would be interested to see them.
Old 05-21-2007, 03:55 PM
as you can see in the photo it has snaped were the locating pin goes. also you can see how the counter weight has come into contact with the plastic gear.
when the shaft is in one peice the gear cant! come into contact with the counter weight so the shaft must have broken first then the gear has moved back and come into contact with the counter weight (this is my therory) so how did the shaft break its not under any load the impeller has no marks on it to sugest that it may have been jamed.
i hav orderd the parts and there very inexpensive but i dont want it to happen again.
Old 05-21-2007, 08:18 PM
You are absolutely right. I'd say the shaft was damaged when the pin was pressed in. This is a very, very rare case. I'd put it back together and not worry about it.
Old 05-21-2007, 11:23 PM
sprocket74 sprocket74 is offline
lufc
My 06 de300 did the exact same thing, except when my shaft broke it took out the internal water pump bearing as well.
Old 05-22-2007, 03:43 PM
sprocket how do you reckon it happened ,i am thinking that the bearing has worked its way out of the seating which has allowed the shaft to move around and eventually snap
Old 05-22-2007, 07:45 PM
From the GGs I've rebuilt, those bearings are a pretty tight press fit in the side cover. I had to grind special "fingers" for my slde hammer puller and use heat to extract them. I see the bearing outer race is cracked. Was it seized? Its tough to say what damage came first.
Old 05-23-2007, 07:43 AM
If I was to guess.
I'd say , when the shaft broke the drive gear was smacked by the counterbalancer causing the bearing to crack.
Old 05-24-2007, 04:24 PM
it wasnt the bearing in the side cover but the bearing pressed into the engine side and no it wasnt seized.
Old 05-24-2007, 04:25 PM
Originally Posted by gasgasman View Post
If I was to guess.
yep sounds good, so how did the shaft break!
oil in cooling water Klausen Enduro Engine - 2 stroke 10 08-06-2011 09:35 PM
Transnission shift shaft. Trailrider Enduro Engine - 2 stroke 15 02-28-2010 05:10 PM
Balance shaft removal. darren Enduro Engine - 2 stroke 3 11-15-2009 05:18 PM
help and advice please 400 output shaft Paul Somerville Enduro Engine 4 stroke (including EFI & Exhaust) 0 11-01-2009 03:14 AM
pv actuator shaft broken help plz fullthrottle Enduro Engine - 2 stroke 0 07-26-2008 12:46 AM
