#11
the failure on my model occured where the water pump shaft was machined down from 10mm to 8mm this same area is where the pin is pressed through for the plastic drive gear. Although I am sure it was a fluke occurance I think that leaving the water pump shaft 10mm right through would have helped the situation.
#12
The shaft may have not been heat treated properly,or the case is misaligned.
If the shaft wobbles-eventually it will fail from fatigue. |
oil in cooling water | Klausen | Enduro Engine - 2 stroke | 10 | 08-06-2011 09:35 PM |
Transnission shift shaft. | Trailrider | Enduro Engine - 2 stroke | 15 | 02-28-2010 05:10 PM |
Balance shaft removal. | darren | Enduro Engine - 2 stroke | 3 | 11-15-2009 05:18 PM |
help and advice please 400 output shaft | Paul Somerville | Enduro Engine 4 stroke (including EFI & Exhaust) | 0 | 11-01-2009 03:14 AM |
pv actuator shaft broken help plz | fullthrottle | Enduro Engine - 2 stroke | 0 | 07-26-2008 12:46 AM |
