breather tube
started the bike today as i havent been out on it for about a month, ive notice there's some white smoke coming out of a breather tube from the head think its the power valve breather tube? did have one or 2 drops of fluid come out but it stopped when it was up to temp..... also latlry the bike has taken quite a fair few kicks to get it going.... new plug & filter is clean
any idea? |
Does the bike always take a while to start or only when cold? I've had bikes in the past that were absolute pigs to start if left for more than a week unstarted. |
the bike used to start first kick from cold without fail, just slowly getting worse now.... also if i come off or bike is put on its side its a real pain to start hot or cold
Have a look in the exhaust port and see if theres much blow by on the rings. When was the last time it had a top end?
i fitted new exhaust sealing rings about a month ago so no sign of it blowing as fir the top end idea.... ive had it nearly a year & hasnt been done since ive owned it, i'll see if i can borrow a compression tester from somewhere, what presure should it be roughly? should have said earlier but its a 2000 model 300 EC
I'd be aiming around 165-175psi for a stock engine.
new GG member with some GG questions powervalve breather and overflow bottle | swazi_matt | Enduro Engine - 2 stroke | 8 | 02-04-2011 10:24 AM |
white gunk coming from crankcase breather tube | Crankin04 | Enduro Engine 4 stroke (including EFI & Exhaust) | 22 | 07-18-2010 09:58 AM |
Oil leak from breather pipe TXT pro 250 | jamesukm | General Discussions & Announcements | 0 | 04-22-2010 12:59 AM |
pv breather | jprh | Enduro Engine - 2 stroke | 5 | 02-21-2009 08:38 PM |
Take out spark arrester for FMF PCII? PV breather + Silencer lengths | gasser250sm | Enduro Engine - 2 stroke | 0 | 02-20-2009 02:00 PM |
