Cylinder head o-ring question
Ok,, so I'm finally getting around to messing with the blown o-ring gaskets on my 97 gg 250. Tonight I rolled the bike into the center of the garage and started in,, 25 minutes down and I have the cylinder head in my hand. Yes the inner o-ring was crunchy and traces of blowby in two passages. I guess that's the smoking gun. I go thru the sleeves of gasket kits from engine kits I have done or helped others do. I also got a couple given to me from guys leaving the gg fold back in the early days. Out of everything I have a set of newer 250 o-rings and I think a set for this. The outer o-ring is not black but a brownish. Is this a cyl head o-ring? Or for something else? Size is perfect.
Steve 16 Beta 350rr 04 KTM 525 sx/exc gone 03 KTM 625 sxc-rehab unit-did its job and now gone 03 GG 250 ec-gone 97 GG 250 ec Gone |
Steve,
Brown is good, likely EPDM, better than BunaN rubber. I've had inner head orings like this but never an outer. |
Ok,, great I feel better about putting this back together. Thinking about taking the head up to Mike up in Dupont to have it surfaced. since I did have an issue.
Check the cyl too, especially the o-ring grooves. Easy to clean up the surface on a glass plate with some #400. Probably even do it on the bike with a small plate and stuffing the bore and water jackets.
Usually when that rubber is hardened and takes a set, its a sign of high temps. Could the bike have overheated for another reason and caused this? |
I swapped out carbs and stayed with the jetting from the old carb. May need to rethink that,, it's the same sized carb but a newer one. Also an airstryker. I did not think of rejecting for that factor at the time. Sounded good and ran 100% so I figured carb was good.
Dyna Ring Question | jdosher | General Discussions & Announcements | 0 | 03-30-2011 06:24 PM |
cylinder head Question? | whodat | Enduro Engine - 2 stroke | 3 | 12-27-2008 12:54 PM |
Ring Question | PEB | Enduro Engine - 2 stroke | 4 | 02-14-2008 01:10 PM |
Head-gasket O-Ring question | FFRDave | Enduro Engine - 2 stroke | 5 | 01-12-2008 09:56 AM |
New cylinder head | Kent A | Enduro Engine - 2 stroke | 8 | 05-01-2007 01:43 PM |
