Old 01-09-2011, 09:59 AM
2stroker 2stroker is offline
Hi there, and happy new year gassers!
Well, after a long journey testing several sets in my 300 GG quad, I found the perfect formula!
pilot 38
main 182
raise the cilynder to clear the ehxaust port
set the squish to 1,00 mm
remove the 2 washers from the powervalve setup
NIEG first clip from above
and the most important, throtle valve number 9, instead of number 7!
I ran sea level, 5 to 15 degrees celsius.
Now, the quad just flyes!
Old 01-09-2011, 11:34 AM
hannesd hannesd is offline
pilot 38
main 182
what's the difference between the slides?
would you have a pic or make a drawing, or even discribe it?
hannes.
Old 01-10-2011, 03:06 PM
the GG Keihin throttle valves have a number stamped on it, and the greater the number the more air flow moves into the carb. So, keeping the same needle and raising the valve number, you get a leaner mixture, especially in low range.
Hope it helps.
This is a mode we do in europe, I saw it in a French forum.
Regards
Old 01-10-2011, 04:09 PM
Hope it helps.
Regards
it should help :-)
where did you get that nr 9 slide?
Old 01-10-2011, 04:54 PM
Hi hannesd,
I borrowed it from a friend of mine and did the necessary machinig on my n?7 slide to equal the n? 9 one. It is an easy job if you get a drill with abrasive sand paper rollers. All you have to do is to cut about 1,2 mm (on slide n?7 profile) to obtain the n?9 intake curve.
I will try to send you a picture to you if you send me your pm.
Old 01-11-2011, 02:01 AM
Hi hannesd,
EXCELLENT !
thanks, hannes.
Old 01-16-2011, 12:39 PM
Originally Posted by hannesd View Post
EXCELLENT !
thanks, hannes.
i did the slide mod and tested it today, it does run much better now.
idle is still rich but will swap the 40PJ to a 38PJ.
MJ is at 175 now, maybe change that to 178 or 180.
thanks to 2stroker
Old 04-12-2011, 05:37 PM
Dude Dude is offline
How is this bike running.
ec 300 sub port Gasgasogeros Enduro Engine - 2 stroke 13 10-24-2010 03:04 PM
Minor leak from exhaust port help? jetfish Enduro Intake/Carburetion - 2 stroke 5 12-24-2009 06:10 AM
How do I check port timing? moff747 Enduro Engine - 2 stroke 1 04-08-2009 05:27 PM
FYI, check BDC piston/lower port clearance. socalscott Enduro Engine - 2 stroke 3 11-26-2008 01:43 PM
Changing my 400FSE to SM smnl4l General Discussions & Announcements 0 11-28-2007 11:46 PM
