Old 04-17-2011, 10:35 PM
mike989 mike989 is offline
Default 300 PV question
Can you remove the cylinder with the PV assembly intact? I had a very minor sieze on my 04 300, so I need to do a top end.
Hopfully I can find a shop in Vegas to do the machine work.
04EC300
04Wild450
07FSR450
Old 04-17-2011, 11:48 PM
roostafish's Avatar
roostafish roostafish is offline
Yes, you can remove it with the assembly in tact. You must unhook the actuator arm though. Take the starboard side cover off, behind the exhaust pipe, unhook the top of the actuator. You will have to to loosen the base nut anyway.
Mike Sheetz
OMRA #21AA
What will I be riding next? Christini GG 300?
'15 KTM 300 XC-W
'08 EC 250 (Gone to new happy owner)
Gran Prix Cycle
LTR Suspension
RB-Designs
Old 04-18-2011, 12:56 PM
Thanks roost..
04EC300
04Wild450
07FSR450
Old 04-18-2011, 07:33 PM
gasser's Avatar
gasser gasser is offline
The little nylock nut on the top of the actuator arm should be locktited so heat it up a bit before removing. A lot of us have found out the hard way that it's real easy to break the threaded post that's welded to the actuator cam. The nylock nuts can be picked up at Lowes in a bag of 4-5 for a couple of dollars.
Old 04-18-2011, 08:47 PM
GMP's Avatar
GMP GMP is offline
There is a chance you will break the stud anyway, sometimes the nuts are too tight. Its a good idea to pick up a spare actuator plate when you buy your top end parts, there cheap.
Oh, don't pull up on the arm or you may move the governer and dislodge the balls.
Old 04-19-2011, 12:25 AM
Thanks guys.
Something tells me those bits of info would not be in any manual.
04EC300
04Wild450
07FSR450
