2015 EC300 First Ride
Took the baby out for her first break in ride yesterday... My thoughts? Cautiously Optimistic😐
- E-button didn't do a thing. Nada. Since its brand new I'm going to check that the battery is connected. If it is I am going to begin the troubleshooting... - After cranking, with clutch still pulled in, it begins to slip/disengage and if I twist the throttle a little, bike starts to roll. going to check the adjustment, but sure hope I don't have to open it up this early and check the plates inside. Ok, negatives are out of the way, so the positives... - Bike lugs amazingly well in first gear! Can't wait for some tight techy terrain. - I am over 200 lbs. Bike didn't think twice about hauling the weight around... - Suspension handled things nicely! At some point I will look to re-spring, but for now it felt good and I will just fine tune it best I can. - Riding area was nothing but sandy whoops. Lifting the front wheel up was effortless, and the bike had way more to give than I was able. - Ran Motul 510 at 40-1. Just a little spooge from the back, but I've seen worse. All things considered, if the estart and clutch are sinple adjustments, then I am extremely pleased. If the estart is hard broke and I need to get into the clutch basket to get it working properly, then I am not so impressed. Optimistic in New Mexico, Rob |
I'm a little confused here. U say u were breaking it in; is this a brand new left over? Any Kms on it at all? The reason I ask is, if it has been sitting, and not been used, the clutch plates will be dry and cause the symptoms you have described.
Also, I had a Honda 300 Rancher before that sat for 3 years. The electric starter didn't work on it when I finally got to try to start the bike up. After taking the starter off and opening it up, I found that one of the brushes were dry seized in the upward position. Might be something to look into. |
Brand new, 0 miles
Yup, it's brand new! 0 miles when I started yesterday. So with the plates get "wet" the more I ride it? 😳🙈
I'll let you know what I find on the battery/starter... Thanks, Rob |
A buddy of mine just kept pumping the clutch lever for about 15 mins with his bike running/idling to get the plates nice and wet. U could also take the clutch cover off, pull the plates out and dip them in oil.
2015 Gas Gas EC300 $6200 | John O | Used Bikes | 1 | 12-11-2015 04:04 PM |
LRBDS (Last Ride Before Deer Season) 2015 | twowheels | Mid-West Forum | 2 | 11-21-2015 06:33 PM |
gasgasman's 2015 250R ride report | gasgasman | Ride Reports | 7 | 04-02-2015 08:40 AM |
2015 MTDR Spring Ride @ Loretta Lynns | skraMnoR | SouthEast United States | 6 | 03-25-2015 07:35 PM |
Wudi 17 Ride/March 5-8, 2015 | Jim Cook | General Discussions & Announcements | 37 | 02-25-2015 04:21 PM |
