2007 EC300 wiring help
After attempting to read the factory wiring diagram I've determined my bike isn't wired per the diagram. So I figured I would find which wire is hot and make my own to be able to install a dual sport kit.
I have the 2k-2 ignition, wires leave at 10:00. I have a plug under the bars that would appear to plug into the head light. It has a purple wire, a green/yellow wire, and an un-wired place to the plug. I've measure across the wires and from both to ground and there was 0 VDC. I have a single purple wire under the bars and measured 0VDC across ground. I have a single yellow wire and measured 1-3 VDC across ground going up to 3 as I revved the bike. I have a three wire plug under my seat with white, purple, and green/yellow wires. I measured every way possible and got 1-3 VDC across the white and green/yellow wires as I revved the bike with the rear brake pedal applied. No other combinations across wires or to ground generated any voltage brake or not. What am I missing? Any help would be GREATLY appreciated. Would I be better off buying a battery and wiring to a battery? Any suggestions on a small light battery and how long will it last powering the headlight and an lcd taillight? Thanks! Josh |
2003 ec300 wiring | Toshy | Enduro Electrical & Wiring | 0 | 09-28-2016 12:39 PM |
2007 ec 200 wiring mess | jason tati | Enduro Electrical & Wiring | 9 | 05-30-2016 04:30 PM |
2002 ec300 light wiring and speedo wiring help needed. | andy176 | Enduro Electrical & Wiring | 0 | 02-04-2014 07:38 AM |
Wiring help with GasGas EC300 | Hicksi | Enduro Electrical & Wiring | 7 | 07-14-2011 10:13 PM |
06 ec300 wiring? | jimbolaya | Enduro Electrical & Wiring | 3 | 08-28-2007 08:26 PM |
