#211
[QUOTE=
All I did was loosen the cap on mine so far, it came right off with a good adjustable plumbing wrench. A little worried on this octagonal socket deal you mention. But i think that is for taking the cartridge apart, am I correct? Again what size is that...I see plenty on Amazon but don't know what size to get.[/QUOTE] Correct, the small octagonal thingy is to open the cartridge. Cheers!!
Oz Current. 2015 ec300r estart, 98 RM 125 2013 Ec300r 2011 Ec300e 2009 Husky TE310 1982 XR500 Honda 1981 KE100 Kawasaki 1978 GT80 Yamaha |
#212
So I broke down the Forks, emptied the fluid out of the slider chamber and it was like everyone else said being dirty. Cleaned up all the fluid, tried to measure it and I got 200cc out of each leg. So maybe with the rest that was on the various surfaces maybe 250cc is my best prediction. Which is well short of the 300 minimum and 320 standard. I put in 320cc into each. So at least the main oil is changed and good practice for me. I also took the time to lube the steering stem bearing. It was pretty easy to break the fork down, a lot easier then I thought it would be. I'll probably make a 2x4 holder for my vice for future break down's and for holding the cartridge (I could see needing it for that. Next go around I'll do a video....Probably change it in the spring sometime. Now onto yanking a XR650R motor out of my other bike to give to my brother inlaw to break down. Rebuild time.
Member of AMA, COHVCO, RMAR, Stay the Trail, COTPA Co-Founder of: TrailTaker My site: TrailTaker.com |
#213
Pulled mine down today and was a little surprised to find a few things.
The inner fluid on both forks was 210 which was good but the left hand side oil was dirty whereas the right side was clean? The outer fluid was 250ml on the left fork and 240 on the right??? These forks had bugger all bottoming resistance and also had the dreaded clunk , which is why I delved into them. I also found an alloy spacer? loose on the internal part. The spacer is located at the bottom of the internal cartridge and is near the point where the two pieces meet if the shaft is compressed all the way in. It is held there loosely by a circlip? I did not notice this on the first leg. The PFP adjuster was loose and the spring had heaps of room to move around( about 3mm). I tightened this up and the spring had a little bit of slop still but seemed good. When redoing the comp adjustments I noticed the last fork I did only had 16 clicks instead of about 24? I refilled both the inner and outer cartridges to the specs( 210 and 340ml). I have not had a chance to test the bike as it is late here but I will give it a go tomorrow. Cheers Mark
Xr 250 ( first bike) 98 Rmx 2007 Gas gas 300(swapped for trials bike) 2008 280 Raga replica 2012 Gas gas ec 300 E |
#214
It's a while since doing mine but I can't remember a spacer, I find these forks "use"outer fork oil, it reduces with time.
Interesting. Quote:
#215
I would be surprised if they used 100 ml in 6 months though?
Cheers Mark
#216
after 12 hours mine were at 290 and 300, so possibly, if you feel the legs there is usually a film on them..... i could be wrong, just never seen legs use oil like these.
#217
Geez that is a big loss then. I am still going to be asking a few questions on Monday though, mainly about the PFP and the spacer part.
Cheers Mark
#218
Watching this Sus it out Mark
Seems somewhat strange and I agree thats a load of oil to lose. I've dropped a capful of suspension fluid on the workbench and it goes a fair way.. Also, whats everyone using for bushings/seals in these legs? Any crossovers? The stock ones are tight. Mega stiction, especially if the bikes been sitting for a few days. |
#219
http://www.shop.synergyseals.com/Fork-Seals_c2.htm
#220
Well,
The work I did has made the fork a lot lot better. No more rebound clunk and no bottoming at all. This is a far cry from how I received them after their service. I could almost guarantee they were not bled as Glen and co. have worked out but probably just like a showa etc. The inner cart after pulling it the first time was not right as I did the quick pump thing and a bit of air and oil was released which surprised me as I would have thought it would occur in normal riding? The forks are now how I expected them to be. I had to reuse some oil last night as I realised I only had 200ml or so of new stuff. These forks are really easy to work with( oil changing wise), and as soon as I work out what the go is with the spacer/washer bit I will delve in there again with fresh oil throughout. Cheers Mark
new 48mm Marzocchi forks?? | Dave A | Enduro Suspension | 19 | 11-04-2011 07:48 PM |
2004 ec250 ohlins forks, 46 or 48mm? | Mikeythefokker | Enduro Suspension | 1 | 04-27-2011 10:39 PM |
WP s or marzocchi forks | Stoby | Enduro Suspension | 2 | 08-19-2010 07:16 PM |
