#51
Exhaust port damage
I took some pictures of the cylinder today. I can not feel any damages on the bore with my nail, except for one horizontal line. However it is not deep at all, could barely feel it.
However, my exhaust port as you can see in the first image has a damage. How bad is that? Should that get nicasil replated, or is it okey, or? maincyl.jpg cyty.jpg cyl.jpg |
#52
Ohh! Its cracked at the bottom of the bridge. Yes you must send it to be welded an replated. Most decent plating companies offer this sort of repair. Think US Chrome and Millennium if they are still what they were. Assuming you are in US. There are other reputable places.
'07 EC300 GG '14 TXT250 GG '? 496 CPI Cheetah RZ/RGV hybrid '22 765 Street Triple RS '21 XTrainer '69 Stinger T125 Suzuki '23 TRS 250RR (it's a Trials thing) |
#53
As you are in Sweden, try to contact
https://www.blixtensracing.se/nikasi...ndruro/gasgas/ Sent fra min YAL-L21 via Tapatalk
Anders "So you know, that you're over the hill when your mind makes a promise that your body can't fill" (Little Feat: Old Folks Boogie) 2015 EC200 Racing: TE bars, Rekluse Core Exp 3.0, 38mm Lectron & Ohlins S3 steering damper 2006 EC200: 2011 plastics, Rekluse Z-Start, revalved KYB forks & Scotts steering damper 1998 Bimota Supermono 1986 Duc Mille S2 1975 Guzzi sidecar hack 1961 Morini Corsaro 125 etc |
#54
It is not the end of the world but you will also need a new piston kit.
#55
Ah well. Thats not so fun. Either way. I will be sending both my cylinders (i got 2 gasgas now) for replating and welding.
I found a company in Sweden that does the job and gives me a kit (piston, ring, bearing, etc) for only 4300 SEK (400USD). Also, I wasnt the smartest and didnt replace my bearings inside the engine even though they had metal shavings in them, so I will be opening it again and replacing them. Also, one question. I want to wash the engine components when it is in pieces. Can I wash it or will I damage stuff? My dad told me we should wash it with diesel fuel so im asking you guys if thats a good thing to do or if we should avoid it or use another liquid. Also is it bad to use water to wash? Is there anything I can't wash? Like the crank or the clutch plates? Thanks guys Last edited by Noobi06; 03-18-2023 at 11:10 AM. Reason: we |
#56
Ahh sorry didn't realise you were from Sweden. That seems so cool to me. Total other side of the globe from my islands in South Pacific.
Good luck. Save up and be respectful to your father if he is paying for this. We try hard to be the right parent. But no-one gave is a manual of how to do this.
#57
Well said F5!
You can use Diesel, but low odor mineral spirits is probably a better choice. I have used mineral spirits to clean everything inside the engine without issues. Using a soap/degreaser and warm water will clean the parts just fine, but then you need to fully remove the water and re oil the parts so they do not rust. |
#58
Okey. Then I will use low oder mineral spirits. And assuming the crank and clutch plates won't get damaged by it either.
Yes I agree F5. And don't worry, he won't be dissapointed. Im doing a street legal supermoto with this gasgas. Here in Sweden, they are worth around 6k-9k usd! |
#59
Low odor mineral spirits will not stink up your home and garage as much as diesel.
#60
I got carried away and forgot to say kerosene is what I use, or some call it paraffin.
My starter works great now! | Bobt250 | Enduro Electrical & Wiring | 114 | 08-16-2020 11:38 AM |
Is there a TUNE ECU app that works ? | Mikesbaron | Enduro Engine 4 stroke (including EFI & Exhaust) | 3 | 08-29-2019 03:55 PM |
Anybody have an 02/03 450 FSE that actually works ? | wakeymatt | General Discussions & Announcements | 5 | 08-09-2012 06:07 AM |
Does anyone know how the compression release works? | stay_upright | Enduro Engine - 2 stroke | 1 | 07-24-2009 10:37 AM |
300xc what gearing works best?? | Dingoe | Enduro Chassis & Body | 6 | 02-05-2007 03:47 PM |
