Old 10-16-2013, 04:53 PM
Leo's Avatar
Leo Leo is offline
Originally Posted by Elvis74 View Post
Sorry, but no. There is not enough space for a spacer. The max you can put between is 2mm but that's not worth it!
I made a CAD model for a spacer version but it is much too expensive for me as a privateer to pay for. Making 5 pieces would cost more than 150,- euros per piece. The problem is the high milling volume which means time on the machine.
You tried laser cut?
www.endurohp.eng.br
Sherco ST300 2015 (Trials)
https://www.instagram.com/leocm74/
Brasil!
Old 10-16-2013, 07:18 PM
pscook's Avatar
pscook pscook is offline
Another option is water-jet cutting. Usually cheaper than laser as I remember it.
Phil
(New bike pending...)
Old 10-16-2013, 11:11 PM
Elvis74 Elvis74 is offline
The Standard spacer are water cut! Laser cut is very difficult because of cutting aluminum. Most companies I've ask only cut up to 8 or 10mm. The version for the e-start is a very complicated 3d geometry.
Old 10-17-2013, 12:31 AM
I guess the problem with the estart version is that it is not a spacer as you will need to get the volume by molding around the starter motor.
Back on the original topic, I believe the spacer has a better effect on the 250 than the 300
Old 10-17-2013, 01:25 AM
I hope you can open the pdf file.
It's a 3D PDF where you can see how the e-start cover would look like.
Old 10-22-2013, 06:03 PM
fasteddy fasteddy is offline
Elvis74, spacer arrived today, looks great, will install tomorrow.
Thanks eh...
Ed..
2011 250 Race, kicker...
2006 640 KTM Adventure...
Smartcarb... Done Waiting, maybe later... Lectron... Got one..
Old 10-23-2013, 04:28 PM
Hawkeye Hawkeye is offline
Back in 2002, my tool and die making neighbor made me a similar spacer out of 3/8'' aluminum plate (9.525mm) using an EDM machine (wire-cutting). Turned out great. Only difference from Elvis' piece is that it used a separate bushing for the center bolt, and I just silicon-ed that to the stock cover.
Seemed to add some low end to my 2002 300XC, and was pretty trick at the time. I later had a chance to get a real deal on a Checkpoint PV cover and am using that now. I think I may still have the spacer in my spares box if anyone is interested.
"Conviction is a luxury of those on the sidelines."
'13 Beta 300RR - race bike
'02 GG300XC - "Billie Baroo"
'01 DR650
'02 GG 280 Pro
'06 YZ 250
'07 WR450
'00 TT125RL
'94 YZ200 - custom keeper
Old 10-23-2013, 05:21 PM
Neil E. Neil E. is offline
Excellent work (pdf drawing rotates). I've thought about making one myself. I'm not sure of the depth available behind the starter motor, but you might need to add a counterbore so the center screw is recessed to clear the motor. Are you allowing enough space for the plastic cover/motor shield to be retained?
Old 11-13-2013, 09:39 PM
JP4's Avatar
JP4 JP4 is offline
Mathias
PM sent re: PV spacer.
Jason
Old 10-07-2018, 09:17 AM
Stoychew Stoychew is offline
The pdf cant be opened, could you upload it again?
LTR Power valve cover skid jackson Enduro Product Reviews 22 09-04-2017 02:42 PM
LTR power valve cover $40.00 GAKLX Parts 6 10-04-2013 09:42 AM
LTR power valve cover Bailey28 Enduro Engine - 2 stroke 11 02-16-2011 04:23 AM
Adjustable power valve cover SeanUK Enduro Product Reviews 11 07-11-2009 05:11 AM
