#11
Sure. I think. My camera's battery is flat. I'll try and get it sorted in a day or two. Have put it on charge.
#12
Image 1
#13
Image 2
#14
Image 3
#15
Awesome. I actually do have that same screw on mine for air bleed. So should I loosen it turning left or tighten turning right? How far? Should I just go all the way one way then try starting every rotation back until it starts?
Lol, sorry I am still a newbie with the Gas Gas 4t's :P. Thanks again for Pics! Crankin04
04' GG FSE 450 Live Easy, Ride Hard! |
#16
I just adjust it to give the fastest idle, that seems to also provide the best starting.
#17
Thanks, Crankin04
#18
I have no idea now! It would depend on the specific bike anyway. It'll change with a big temp difference as well so you may find you need to adjust between winter and summer. Just try it both ways until you get the fastest, most even idle. There'll be a range of about 1/4 - 1/2 a turn where it is good but doesn't change much. Set it in the middle of that.
#19
Do you think it has something to do with air bleed screw once the bike is warmed up and hot? Maybe some other issue causing that? Thanks for all your help! Crankin04
Spark plug | gasgas125sm08 | Enduro Engine - 2 stroke | 0 | 03-08-2010 09:42 AM |
EC 250 Spark plug | Grampy | Enduro Engine - 2 stroke | 11 | 12-16-2008 12:24 AM |
01 ec300 spark plug.... | jhendr3702 | Enduro Electrical & Wiring | 1 | 07-02-2008 07:53 PM |
Spark plug gap???? | Bandit9 | Enduro Engine - 2 stroke | 1 | 08-29-2007 05:26 PM |
