Old 04-19-2018, 12:40 AM
gasman88 gasman88 is offline
Default Squish
So I've been thinking about getting some head work done. Maybe it would clean up the little rich stumble up to 1/4 throttle. How do it measure squish, but most importantly, is there anyone on here that does quality work? How much would it cost?
Old 04-19-2018, 01:15 AM
Search my head thread.
http://www.gasgasrider.org/forum/sho...highlight=Head
Old 04-19-2018, 08:27 AM
nknudsen's Avatar
nknudsen nknudsen is offline
What have you done already to help get rid of the stumble/richness? It doesn't need head work to clean that up, it's going to be something else.
Noah
16' Specialized Fatboy trail
02' ZRX 1200r R.I.P.
15' TW200
Old 04-19-2018, 07:28 PM
Funny you say that. I spent most of the night last night trying different things. I stuck a genuine keihin 40 pilot, apparently the one i had tried to use was a knock off. Longer threads, bottom of jet was a little different looking. I had no luck with the 45. ( i have a 38,40,42,45,50 somewhere)) and went from a 180 to a 178 main ( i have 168, 170,172,175,178,180 mains). Stock needle on the leanest setting. #7 slide. 200ish feet above sea level, 45 degrees. It ran the best yet. No hesitation. No weird lean mixture sounds. It smoked when warming up, but it all went away when it was warmed up. I found that kind of alarming. I am running semi synthetic smokeless/ashless oil. Low flash point. Around 175 degrees. I was think of putting the clip back on the 3rd position. Maybe put the 180 main back in, put the 40 pilot seems nice. Maybe try a 42. I took it for a 10 min balls to the walls ride and nothing changed. Although when i stopped coolant started leaking out the coolant tank. I accidently melted it with a torch. I guess i could read my plug and get a questimation? I don't want to run to lean. The power is night and day difference though and so is the idle.... Here's a video. It's early in the morning but you get the idea. It was hard to see. https://youtu.be/Z9NdNtlmMOY
Old 04-21-2018, 09:39 AM
nknudsen's Avatar
I'm glad your making headway! Playing with jetting and carb settings can make such a difference on a stock engine.
Noah
15' TW200
Old 04-23-2018, 08:10 PM
It sure can man. I'm not nearly done yet either haha
1.6+ mm squish paulos Enduro Engine - 2 stroke 8 07-08-2014 08:28 PM
Squish help. Ud_luz Enduro Engine - 2 stroke 39 02-14-2014 11:02 PM
Squish adjustment Marcão Enduro Engine - 2 stroke 20 07-12-2012 09:37 PM
RIDICULOUS squish. as always! stainlesscycle Enduro Engine - 2 stroke 30 10-19-2011 01:11 PM
Squish / MSV calculator Bailey28 General Discussions & Announcements 0 09-09-2011 08:27 PM
