Old 10-04-2016, 10:49 AM
Neil E. Neil E. is offline
I can't comment on the rewind since I've never tried it myself. Maybe 1 ohm is not close enough to the factory specification. The other thing I wonder about is the actual direction of winding. That means how you wrapped the wire around the poles. The wraps should alternate, CW on one post, then CCW on the next. Poles wound in the same direction will cancel each other out and you will have almost no output.
This article has lots of useful information:
http://www.spokanister.net/ktm_stator.htm
The other thing to consider is the quality of the flywheel magnets. Do they have a strong force to them?
2011 EC250E
Old 10-04-2016, 07:54 PM
kiwigasgas kiwigasgas is offline
Yes i worked thet out the hard way, i would them all the same way.
so i cut them off and started again, re wound them the correct way and got 50 volts AC, connected the trailteck and still got 0.5 volts
Nearly threw a wobbler but i tried to connect it to the battery anyway and it jumped from 13 volts to 13.4 and could hear a tiny bit more load on the engine. looks like its charging.
Will it not show a clear 13volt output util it is connected to the battery?
Old 10-04-2016, 10:41 PM
(F5)'s Avatar
(F5) (F5) is offline
Great perseverance. If you don't have at least a large capacitor (or ideally a battery) you can fry the regulator.
'07 EC300 GG
'14 TXT250 GG
'22 765 Street Triple RS
'21 XTrainer
'69 Stinger T125 Suzuki
Old 10-05-2016, 10:18 AM
A full wave rectifier requires a battery to be in the circuit, so your results are correct. Good on ya for completing the task.
2011 EC250E
Old 10-05-2016, 05:17 PM
Yay sweet, thanks for all the info, god knows hownpeople did this in the old days with no internet. Starter works perfect, better than any crappy ktm one. Got my 48mm kayabas on it now, bike is awesome and at a fraction of the cost of a new bike
Old 10-06-2016, 03:59 AM
(F5)'s Avatar
My sss were good, but yz valving got a bit tiresome. Got local k-tech guy to do their club valving spec on it and I haven't felt the need to adjust it, just so much better. I'm in wgtn if you need details but chch Linton will be good. Not sure for Auckland.
'07 EC300 GG
'14 TXT250 GG
'21 XTrainer
not charging battery OLD.IT Enduro Electrical & Wiring 2 06-21-2015 03:01 AM
Charging phone on 2011 EC300 Quigs Enduro Electrical & Wiring 9 03-07-2015 12:55 AM
Battery Not Charging GLantern Enduro Electrical & Wiring 6 08-25-2013 03:45 PM
