Rotella substitute ?
I can't find the Rotella for $20/gal. anymore.
Would this Valvoline work just as well ? NAPA has it on sale for $20. I'm thinking I should grab a case of 'em. |
Since you posted in the 2stroke section I assume you are using this for the tranny. If so I would not spend the extra on synthetic. Just use the Rotella 15w40.
I would say the Valvoline would be good as well just a little more $. |
I would steer clear unless you know the amount of friction modifier used.
The nice thing about rotella (both dino and syn) is that it is jaso ma (motorcycle rating) approved for use in wet clutch motorcycles - so no clutch slippage due to addition of friction modifier.... jeff
The 15W-40W works good, just a bit more drag when cold.
Like web master said rotella non-sythetic 15-40 "triple protection" has the jaso ma or motorcycle approval rating. Other diesel oils may not or do not. Even rotella sythetic is not jaso ma approved. Not that it means anything but like webmaster said it could cause clutch problems with friction modifiers.
Track-N-Trail Cycle LLC trackntrailcycle.com 2011 Beta 400 RR (sorry ) 2010 GAS GAS XC 300 2007 KTM 200 XC |
I switched from Rotella to Amsoil 0w-40. I like the Amsoil much better even at twice the price. Much less clutch drag than the Rotella and much easier to find neutral.
2004 GasGas DE250 |
jeff p.s. I just checked the rotella website and rotella t6 full synthetic 5w40 has a jaso ma (motorcycle w/ wet clutch) rating : http://www.shell.com/home/Framework?...t6_detail.html
Walmart has it for $20
How much gear oil are yall running ? Does a liter sound about right ?
My tranny holds 900 ml
Rotella? | ktmguy23 | Enduro Other... | 3 | 04-22-2010 05:57 AM |
Rotella T 5w-40 synthetic? | joey11 | Enduro Engine - 2 stroke | 6 | 03-21-2008 02:33 AM |
Where to buy Rotella T Syn oil in NH? | nhrider | Enduro Engine - 2 stroke | 5 | 08-13-2007 10:25 PM |
Substitute Parts | asistech | Enduro Engine - 2 stroke | 2 | 12-14-2006 08:57 PM |
