Old 11-09-2021, 05:17 PM
JAD JAD is offline
Default Rear Brake pedal spring..where does it connect?
Hi all, my brake pedal return spring is missing and I cannot for the life of me work out where the new one should fit. The brake pedal end is obvious but where do I attach the other end? The parts diagram is no help....
Thanks in advance...
Old 11-09-2021, 06:55 PM
It has been a while since I seen an 07 but is there a hole in the tube surrounding the swing arm pivot bolt in the frame?
Old 11-10-2021, 11:33 AM
JAD JAD is offline
Thats what I thought but I cannot see one.... I shall clean the area, get a torch and my specs and have a closer look!
Thanks..
Edit, having cleared away some muck it appears to just hook over a small fillet on the frame... seems to work anyway.
Rear brake pedal return spring. masterbill Enduro Chassis & Body 1 04-06-2019 08:45 AM
brake pedal spring? spooly Enduro Chassis & Body 20 05-09-2014 04:37 PM
Rear brake pedal wheelie "Wanted to Buy" & "Want To Trade" 1 02-13-2013 01:10 PM
2004 EC 300 Rear brake pedal Spring??? Scar13 Enduro Chassis & Body 2 12-28-2011 08:25 PM
Rear brake pedal HydroDog Enduro Chassis & Body 0 03-09-2008 10:48 PM
