Old 04-13-2009, 01:17 AM
goose202 goose202 is offline
Default Swingarm bolt
Hi all.
Trying to remove the swingarm bolt on my '04 EC300. It won't move. According to the parts diagrams, the head of the swingarm bolt has a side missing. At the risk of looking like a clown when someone points out something obvious I've missed... it looks like mine doesn't have the edge missing! I can't see how the bolt can be removed.
Pic 1
Pic 2
Is the bolt not moving because it's seized in there, or does my swingarm bolt look different to everyone else's? Help!
Thanks,
Bruce.
Old 04-13-2009, 04:19 AM
Brian VT Brian VT is offline
That's what they all look like. Keep at it and do a search here. There's lots of tips for getting it out.
Old 04-13-2009, 04:22 AM
jiauka jiauka is offline
Your axle looks standard, it is pretty normal to be seized, do some search, i.e.
http://www.gasgasrider.org/forum/sho...=swingarm+axle
Loose all linkage and sock, and get a bigger hammer
have fun,
j.
Old 04-13-2009, 09:16 PM
Thanks guys.
Now that we've established it looks normal, I'll go with some of the normal removal tips. I do think a bigger hammer might be in order though.
Old 04-14-2009, 05:54 AM
I've heard that loosening the motor mount sometimes helps too.
Old 04-14-2009, 07:35 AM
Just support the frame on the other side if your forced to go to that extreme!
Old 04-14-2009, 08:01 AM
Of course!!! The frame was resting on some serious wood parts.
This was my last attempt before using an hydraulic press.
After the usual light hammer, I loose all the linkage, shock, etc... and tried a much nicer method using a DIY extractor.
8mm tap on the left hand side.
DIY puller
But I didn't suceed with it either, then I went the "bigger hammer" approach.
have fun,
j.
09 EC 450 Swingarm bolt torque ? Wiggy Enduro Suspension 6 01-26-2010 04:13 AM
That pesky swingarm bolt AZRickD Enduro Suspension 13 07-11-2008 09:13 AM
