Old 05-08-2017, 06:24 AM
welsh.Z.S. welsh.Z.S. is offline
Default How to remove clocks
On my 09 EC 125 I have the red rectangular clocks , but they've never worked since I had the bike , how do the clocks come off so I can maybe try changing the batteries etc
Old 05-08-2017, 07:27 AM
Anders Anders is offline
The bracket is fixed to the top triple clamps with a couple of M5(?) screws. If you undo them, I think you will figure out the rest.
Old 08-23-2017, 09:15 AM
I need to remove the headlight assembly to get to this but I can't seem to work out how to remove it 🙄😂
Old 08-24-2017, 01:32 AM
The headlight is fastened by rubber bands around the fork legs. Undo the two rubber bands at the top and the headlight assembly can be lifted up / forward.
Old 08-24-2017, 07:25 AM
_Hammy _Hammy is offline
You can also probably remove the battery from the underside of the speedo using a coin once the headlight is off
Can I remove my EFI and install a Carb? safetythird Enduro Engine 4 stroke (including EFI & Exhaust) 9 10-08-2015 05:14 AM
How to remove Flywheel? Fabry Enduro Engine - 2 stroke 12 08-16-2013 03:27 PM
How do I change the clocks from KPH to MPH KTMAndy Enduro Electrical & Wiring 5 04-20-2012 06:28 PM
EC200 06 Clocks jamesfordham Enduro Electrical & Wiring 9 04-20-2012 03:40 PM
how do you remove the kickstart noobi Enduro Chassis & Body 13 09-22-2011 03:31 PM
