#31
The M will be leaner only on the diameter of the needle which will work in conjunction with the pilot and only effect the running below 1/4 throttle.
#32
I think my main target is to lean things out to the 1/2 throttle point. How does the lean to rich 1/4 to 3/4 throttle scale work as it relates to the needles? Do you move up and to the right to get leaner in that section of the throttle response? |
#33
The lean -> rich 1/4 to 3/4 relates to both the taper and the length, as they both have an effect in this area. The length is just a clip positon change, so if using a CGL you would run it in the same clip, and it should run similar, however the taper is leaner, meaning as you open the throttle more, it will begin to lean off more aggressively from the diameter.
My suggestion would be that if you want to go that path, purchase a few different ones and spend the time testing. Speaking of testing, what (if anything) have you tried with your current setup? Have you tried lifting the clip one pos? |
#34
I replaced the 42 pilot with a 40 this weekend, though I haven't had a chance to ride the bike yet (dealing with a fuel tank issue ). My plan of action is to test the 40 pilot and see how she does. If I'm still getting a fair amount of drool from the pipe, I'm going to switch the needle from #2 to #1 and see how that goes. Given that's the leanest setting on the needle, my next step would be to look at a slightly leaner needle to try...hence all the questions |
#35
I'm running the same bike here in New England and I am running a 40 pilot but am also using a JD kit. I don't think anything I've done has help the drool coming out of the pipe
#36
Out of curiosity, which JD needle are you running and where? And more importantly, what's your typical elevation and temp range? Given your location, the temps right now probably aren't conducive to riding though...lol. |
#37
What are you talking about we have an enduro next week. I'm running the red needle in the second from top position and most of the riding is right around sea level to slightly higher when we ride in the hills. |
#39
At least the cold air is nice and dense - she'll make good power Need to get out and test the leaner pilot and then it'd be a clip leaner on the needle. We'll see.... |
#40
60th year of the Netra Snow Run in CT. Feb. 9th. Only time it gets postponed is when it's too warm. I've been stupid enough to take my bike out in -9?F one year. I was much younger and dumber then.
Uk Jetting | Packman | Enduro Intake/Carburetion - 2 stroke | 1 | 07-26-2013 04:28 PM |
How do you know you got your jetting right ? | Krisden | Enduro Intake/Carburetion - 2 stroke | 21 | 07-01-2012 03:49 PM |
GG jetting | Gasgasogeros | Enduro Intake/Carburetion - 2 stroke | 0 | 02-21-2011 06:39 AM |
jetting | macho comacho | Enduro Intake/Carburetion - 2 stroke | 21 | 03-10-2009 03:11 AM |
2005 EC200 jetting help | fury1 | Enduro Intake/Carburetion - 2 stroke | 17 | 12-20-2008 01:55 AM |
