Old 08-23-2011, 05:18 PM
Default 2011 headlight bulb
it did not take long for me to find my head light bulb in many little pieces inside the headlight. I don't suppose there is an led that could fit inside the existing headlight?? What are you guys running for replacement bulbs? I;m guessing it is a install a new one for passing inspection and forget about it till next year kind of thing??
Old 08-23-2011, 06:59 PM
Mine blew after the 4th ride.
I plan on putting a HID bulb in there next. The OEM bulb is a 35w H4 bulb.
Old 09-11-2011, 02:18 PM
I'm running a 55w 9003/H4 bulb. No issues with heat or vibration.
Old 09-12-2011, 02:32 AM
out of curiosity are the lights run on AC or DC?
Old 09-12-2011, 08:59 AM
GasTimppa GasTimppa is offline
Well the right type of halogen bulp is HS1 35w/35w. Fitting is a bit different than H4, but H4 goes too...
There is no such thing as bad weather! Only riding gear is improper or insufficient
When it hurts you know you're allive!
Gas Gas EC 300 Factory Racing 2012
- Ohlins TTX both front and rear
- Rekluse Core EXP 2.0 + Rekluse clutch basket
- Scalvini full exhaust system
- S3 Head
- Trusty adjustable PV cover
That was ultimate setup for me...
Now trying something else for a while...
Old 10-15-2011, 08:13 PM
Since my post, the reflector inside of the headlamp has tarnished. It turned black.
There are no signs of excessive heat. I don't know if the 55 watt bulb is borderline on the heat output.
I would stay with the 35W oem bulb.
Old 10-16-2011, 05:35 PM
rgranger's Avatar
rgranger rgranger is offline
i am pretty sure this is what I put on my husky, i swear it had the same dim bulb behind the bars as the GasGas does....hey wait a second!
https://www.bajadesigns.com/NET/P-60...Baja+D+(04-red)
Rob Granger / Katy, TX EC300
Old 10-16-2011, 08:24 PM
thats all I could find locally ... it worked fine ... but popped after 3 rides just like the oem .... maybe there are more rocks and roots in my neck of the woods??
Old 10-16-2011, 08:58 PM
Cruiser Cruiser is offline
is the stocker like the stocker used in the ktm headlights 06 newer? if so EE has a small halogen hi/low that plugs in that has a smaller globe. They say they last longer as less weight/thicker glass and its a 45/55w halogen I believe. I was going to get one for my ktm but went H4 instead.. still cant see crap out of that diamond shaped joke they call a headlight..
Steve
16 Beta 350rr
04 KTM 525 sx/exc gone
03 GG 250 ec-gone
97 GG 250 ec Gone
Old 10-23-2011, 11:11 AM
REVERUP's Avatar
REVERUP REVERUP is offline
How many rides before it started turning it black, and was that riding in the hot Texas daylight hours?
Reason I'm asking is I'm thinking of adding a 55WT bulb to my 11's headlight shell for the night portion of this weekends 24 hour. I run my stock headlight shell and 2 trail tech mr 16 HIDs off the handle bars. along with 2 more HIDs of my helmets chin guard. So its not crutial I do this.
Really the bike light is just fill in light as this is mostly open prairie. But if I could get a bit more out of it that would help as you can outrun your lighting in this environment on super dark years as is this years prediction. Little or no moon light.
Thanks for your experience and advice with this in advance.
Roscoe
2001 XC 300 headlamp bulb jhendr3702 Enduro Electrical & Wiring 11 07-21-2011 03:27 PM
Headlight Bulb Kurdt Enduro Electrical & Wiring 1 09-01-2010 10:23 PM
FSE450 bulb vwboomer Enduro Electrical & Wiring 1 04-01-2010 09:01 PM
Bulb rating for 2001 ec300 johns2394 Enduro Electrical & Wiring 0 12-02-2008 01:12 PM
