Old 09-03-2013, 01:58 PM
troffer88's Avatar
troffer88 troffer88 is offline
I haven't measured the 250 rod length so no help there , I also have my head done and Scalvini exhaust so they would be different more than likely
Old 09-03-2013, 02:08 PM
AZRickD AZRickD is offline
My head was RB-modded to a modest 1.33mm squish.
I might cut my Q-Stealth down 4.25 inches.
Old 09-03-2013, 02:45 PM
I have ordered one from Lectron. Thx.
Old 09-03-2013, 03:30 PM
Good work Rick. Give it a go and see what you think. I'm not sure if Dave ran the stock power jet or a shorter one with the MS3 either.
Old 09-03-2013, 04:01 PM
I can't imagine it working with the shorter tube. It needs that Dial-a-Jet beastie kicking in.
Old 09-06-2013, 09:09 PM
I cranked the MS-3 Rod in one-full turn.
Definitely more spunky off bottom. Didn't need (or like) the choke.
I was speculating that I'd need to adjust the PowerJet, but it didn't need it after it warmed up.
I won't be riding in the same place tomorrow so no 1,000 yard uphill sand wash test.
One of the leanish things I noticed before was that when the bike came off a high-speed run or a long climb, it would idle with that arhythmic staccato pa-pah-pah-dum-dum-dummmm. Let's see if that's gone.
Old 09-06-2013, 09:24 PM
One full turn is a pretty significant adjustment.
Old 09-06-2013, 09:30 PM
Supposedly not so significant on the MS-3. Somebody was saying that it was 2 to 1 or 3 to 1 in comparison to the standard Lectron 3-1 rod.
So, take *that* Mr. Jakobi !!
Old 09-07-2013, 01:12 PM
The adjustment helped somewhat with the staccato idle but I could still sense some mid-range flatness.
Additionally, the plastic float bowl is weeping on the left side. You will see a bit of curvature in the photo. The right side is flat and dry.
Old 09-07-2013, 05:32 PM
Hahah! Got me Rick! I do recall Kelly mentioning the initial taper was less aggressive than the conventional MRs.
I wonder if the float bowl leak is also acting as an air leak? Have you removed or retightened the screws? I recall that the one I had wasn't completely level where it mated but didn't leak like that. I always thought that overtightening could somewhat skew the shape.
The Lectron - Review (vs SmartCarb) Jakobi Enduro Intake/Carburetion - 2 stroke 234 01-28-2014 08:13 AM
Smart Carb vs Lectron vs RB-Designs Mod AZRickD Enduro Intake/Carburetion - 2 stroke 49 08-09-2013 12:18 AM
Lectron Carb singletracker Enduro Product Reviews 145 07-27-2013 12:20 AM
Lectron Carburetor Testing & Adjustment singletracker Pictures & Videos 4 01-12-2013 09:37 AM
Lectron Binni Enduro Intake/Carburetion - 2 stroke 16 03-29-2011 09:44 PM
