#11
The only recent wiring schematics are for the E start models.
Not 100% sure that it connects to the yellow straight from the stator, but its deinitely connected into the yellow circuit. I haven't checked the reg from the old bike. The new regulator I received had a different number stamped on the side, but both are leoneli 12V AC regs, both 2 wire. The 2010/13 both appear wired in the same way where it feels from the harness to the chasis and is grounded against the frame, mounted behind the rhs rad. I should probably disconnect the reg/remove the ground and test the voltage unregulated. |
gasgasman's 2015 250R ride report | gasgasman | Ride Reports | 7 | 04-02-2015 08:40 AM |
Honda DI 250r for 2015! | nambo-trev | All Other Bikes... | 3 | 04-01-2014 07:31 PM |
Countershaft/Sprocket seal leaking on '12 250R | Novascotiarider | Enduro Engine - 2 stroke | 14 | 04-19-2013 05:00 PM |
'12 250R is in the house | GMP | General Discussions & Announcements | 66 | 07-03-2012 11:55 AM |
Gas Gas 300 Quad. Will 250r radiator fit? | skoolball23 | Other GasGas Bikes/Quads | 2 | 04-26-2011 08:15 AM |
