Old 09-10-2018, 05:36 PM
vaughn's Avatar
vaughn vaughn is offline
Default Crankshaft flywheel nut
Is the crankshaft flywheel nut reverse thread for all years? This is for a 1998 ec250.
The reason I ask is, I finally got the crankshaft nut off today but it came off with such a fight that it stripped the threads from the inside of the nut. Hopefully the stud end on the crankshaft will be salvageable...anyone know the thread size and pitch etc of that end of the crankshaft?
Otherwise I may be looking for a crank ugh.
Thanks in advance.
Vaughn
Old 09-10-2018, 06:28 PM
john r b's Avatar
john r b john r b is offline
If it is fudged... A machine shop will be able to help cutting new threads or else .
'12 XC 200 TTX Sold
'15 XC 250E Sale pending
Old 09-10-2018, 08:42 PM
vaughn's Avatar
After further inspection I think it will be fine if I run a die on the threads. The sludge was mostly from the nut as far as I can tell.
One thing of note though, the crank flywheel nut (on the clutch side) appears to be standard right hand thread. No wonder she blew out. I got the reverse thread info from the rebuild thread on this site, guessing it may not apply to all years...
Attached pic shows right hand thread, just as a sanity check I unbolted the flywheel nut on the ignition side, and it was right hand thread as well.
Picture has a lot of fuzz on the threads from the shop towel and brake cleaner. Threads look worse than they are.
Old 09-11-2018, 01:32 AM
Thompo Thompo is offline
05 200 was a normal Right hand thread both sides but it had a bolt on the clutch side instead of a nut.
Spent a good while trying it left handed, luckily my impact gun isn't very good lol.
Old 09-11-2018, 06:53 AM
RBrider's Avatar
RBrider RBrider is offline
It was the same way with my '01 XC 200. Right hand thread on both sides of the crank for the 200's.
RB
Old 09-11-2018, 09:25 PM
vaughn's Avatar
Thanks for the replies all! Hopefully this thread will help someone doing a rebuild in the future!
Vaughn
1998 EC250
1975 Kawasaki MC1
1989 Kawasaki KD80X
1988 Kawasaki KD80X
1973 Yamaha CT175
1973 Yamaha MX80
Crankshaft flywheel nut Jonas300 Enduro Engine - 2 stroke 9 06-08-2018 05:27 AM
WTB crankshaft for 06-08 ec450fsr fastisbetter Parts 2 09-29-2013 08:26 AM
crankshaft cross-over whodat Enduro Engine - 2 stroke 2 04-26-2010 06:05 AM
