What's your opinion on "lift" stands
Up to now, I have been using my perfect 17" height and low-priced plastic Rubbermaid 2-step stool that I bought at Lowe's for about $10 (See Below). I see all of these ads for "lift" stands costing anywhere from $50 to $100. Some are overpriced (ok most), while others are scary to be called a lift stand. I have held off buying one these because it is hard to justify the expense. However, lifting the bike up easily is very appealing for maintenance items.
Some examples that I have been looking at: Motorsports P12 lift stand FMF lift stand MSR Pro-lift stand Excel Moto-X Lift stand Ocelot Pro lift II stand (from Chapparal) Tusk lift stand (from RockyMountain) Sears ATV/bike lift (heavy but ok for garage use) Do you use a lift stand and what brand? What are the pros/cons? Any homemade ideas not requiring welding? It would have to be wood or metal bolted together. Here is a pic of my Rubbermaid stand: EDIT: My plastic stand is made by Costco (not Rubbermaid). The height is 17" with a top surface of 12"x10" (12" is side-to-side width). Also, I riveted a small section of rubber mat to the top surface to keep my bike from slipping. They claim a max load limit of 250 lbs. Here is a link to Lowe's. This is a newer version sold by them, but it is very similar. http://www.lowes.com/lowes/lkn?actio...-12&lpage=none
Matt Current: 2009 Yamaha FZ1 Previous: 2001 GasGas TXT280, 2001 GasGas XC250, 2004 KTM 200EXC, 2007 GasGas EC250, 2007 Husqvarna SM610, 2008 Husqvarna WB165 Last edited by MattR; 08-09-2006 at 06:05 PM. |
I like your stand. The first time I saw that photo I thought I might get one too.
I use and sell these http://www.teamhawgracing.com/ Its great not having to bend over to work on things.
I use a fixed stand, somewhat like Matt's, for minor work. For bigger jobs I have one of the Sears atv/motorcycle lift stands. The Sears unit is quite solidly built and has two feet that can be screwed down to make contact with the floor - it is very stable. When not in use it fits under the bike.
this was my first stand,its the ash can for my fireplace
Thank you, Ron |
I have the same stand and it's the sh*t!!! |
FMF stand , or similar types ...
wait til your skippin thru the shop, and yer toe scoots under the lift pedal !! disclaimer:I never skip in the shop, never...
I have boughten lift stands from harborfreight and discountramps both work good. The one from harborfreight has a pin that hold the stand in the loocked postion. Hope this helps
"attn." "new England Boys" | RONALD BRUNDIGE | General Discussions & Announcements | 9 | 11-17-2008 08:19 PM |
"B" piston in an "A" bore? | Kokanee | Enduro Engine - 2 stroke | 6 | 09-04-2006 07:10 PM |
Recommendation: add "Injury/Recover" and "Riding Techniques" sections | MattR | Suggestion Box | 2 | 07-18-2006 09:19 PM |
