Old 01-20-2008, 09:58 AM
Leon_gasgas Leon_gasgas is offline
Default EC250 aftermarket kill button
Hi!
After I went DC for my ec250 07 I have a problem with the connection of a new aftermarket kill switch/button. According to the wiring diagram of the manual the oem kill switch is connected via the horn (grey wire) to the yelow wire (AC power). The Yellow/Green wire to Black wire (ground) of the harness. I disconnected the horn when I bought the bike and the oem kill switch was still working. I connected the new kill switch in the same way but it does not work. The bike starts but the kill button doesn't kill it.
Should I keep the one connection to the black wire of the harness and connect the 2nd wire of the kill switch to the White/Blue wire of the coil? I saw that I could disconnect this wire easily and replace the simple connector with a "double" connector so that the 2nd wire of the kill button can be connected there. Is this the way the kill button is attached on the DE models that I think they don't have the wiring harness of the EC model?
I am waiting for your replies!
Thank you!
Old 01-21-2008, 01:24 AM
Nobody can answer this question? Is it ok to connect the kill switch to the White/Blue wire going from the CDI to the coil? I am asking first in order not to damage the CDI.
Regards,
Leon
Old 01-21-2008, 02:59 AM
There seems to be an error on the gasgas electric schema. The horn is connected to the CDI and the oem kill button to the horn. So, for two days I have been using the horn to shut off the engine...
Best Regards,
Leon
2010 EC250 4T Aftermarket Exhaust Compatibility Jeffro General Discussions & Announcements 3 10-27-2009 04:45 AM
Billet kill switch gasgasman Enduro Product Reviews 1 03-29-2009 12:01 AM
Kill Switch Dingo Enduro Electrical & Wiring 4 12-10-2008 04:23 PM
06 Txt250pro - Kill Switch? monkey8414 Enduro Electrical & Wiring 0 01-15-2007 04:16 PM
