#91
The alignment for the hole was real touch and go with very minimal clearance. I did my best to keep as much meat on the outer edge, but at 2-3mm it really is as far as you can go. Any further and you wouldn't get the caliper bolts lined up. Even with the current setup I really need to be careful in getting the lower bolt started and done up and then apply some pressure to the carrier to pull it into position to put the upper bolt in. Snug as a bug in a rug. Cable is cracked, but was already. This is on the old steed. Everything lines up pretty well. I put a battery in the speedo and spun the wheel up and it was reading so thats a win as well. |
#92
Spacers etc
And the 15mm of axle that sits out So everything is pretty much ready to be swapped over to the main ride, and then taken out for a test run. |
#93
Looking good mate.
I will have to ring you and have a yarn soon. Cheers Mark
Xr 250 ( first bike) 98 Rmx 2007 Gas gas 300(swapped for trials bike) 2008 280 Raga replica 2012 Gas gas ec 300 E |
#94
Those forks were a good find! mine are pretty nice, but definitely seen some dirt, those look like they brand new
#95
Jake,
I missed what you are doing for the triple clamps? Did you bore the GG top clamp?
2011 GasGas ec300R 2011 GasGas ec200 Six Days |
#96
I got a spare GG top triple bored out. Jakes are newer and fit the GG triples
#97
Very first post. The Gas Gas stock forks are a 54mm OD. You can match this with some late model KYBs, however you'll drop 3mm in total offset due to these forks having a shorter axle lug. If you bore out the upper clamp from 54mm/56mm you'll have a larger range of forks to chose from (inc WRF), and depending which years you'll also be able to retain the same total offset.
I'm taking a bit of a gamble by dropping the total offset by 3mm, but I believe it should work well on the 2012+ chasis. Maybe not so well on the older ones which already need a bit more input in the turns. |
#98
My speedo never worked so I never got carried away with that.
'07 EC300 GG '14 TXT250 GG '? 496 CPI Cheetah RZ/RGV hybrid '22 765 Street Triple RS '21 XTrainer '69 Stinger T125 Suzuki '23 TRS 250RR (it's a Trials thing) |
#99
Couldn't quite get my head around why Steve opted to use a WRF axle over a YZF. He had told me it was too short, but end to end measurements were perfect. Given his current situation I don't expect him to sit around explaining things, and for good reason too! Thoughts with you Steve!
So with some measuring, we'll start with the brake side. The spacer is required to do 2 things. Set the center line of the hub, and align the rotor in the carrier. It does this. Then the hub is a constant, and so is the shoulder on both axles (YZF/WRF). The difference in shaft length is 20mm. Basically, when all is done with the shorter axle the shoulder on the floating side would be right on the seal lip, which leaves very little spacer, and a poor sealing surface. You could get around it a few different ways, but none are easy persay. I'm guessing best bet would possibly be running with an axle shaft length between the two/a little less shoulder. I may get a mate to measure up a Honda CRF axle for exercises sake. |
#100
Is there a reason why you want a shorter axel (other than aesthetics)?
One thing I have noticed is that I cannot see any noticeable "float" on the rhs shaft when tightening up. Not sure if this is because the kyb's are a much tighter package than the extremely wobbly (at full extension) Sachs that k am used to where I could slide the fork bottom a couple of mm either way when trying to get proper fork alignment. Or is this due to the spacer sitting slightly inside the fork bottom?
2013 ec250r | Jakobi | Enduro Product Reviews | 163 | 02-21-2016 03:52 AM |
2013 EC250R - 65Hr Report/Review | Jakobi | Enduro Product Reviews | 111 | 03-07-2015 07:33 PM |
2013 ec250r | Jakobi | Enduro Intake/Carburetion - 2 stroke | 2 | 04-17-2014 08:08 PM |
2011 Gas Gas EC250R | EricW835 | Used Bikes | 3 | 10-20-2013 10:58 AM |
