Old 09-08-2017, 01:28 PM
periclesgsilva periclesgsilva is offline
Default Trail Tech Vapor - Gasgas EC300 2014 Racing
Hello guys!
Need some help to instal a "tachometer" cable to my Vapor. Problem: i have the TT with the rpm option, but the old owner of the trail tech unit lost the cable.
Can i make a new cable? To read the RPM signal? I have a conector from a old speedometer cable. The tachometer cable in the TT unit have wires. One black and one red. So, if i put the connector, need to put 2 wires. One black and one red. The red one to the coil and the black in the ground?
Thanks!
PS: Just to inform, i don't have the original cable. So i will try to make one. hard to find the cable here in Brazil.
Old 09-08-2017, 05:17 PM
Trail Tech has the individual cables on their website.
Pretty sure the "tach" cable is just a single wire lead that wraps around your plug wire, the only issue I could see with making one is the plug.
Old 09-08-2017, 06:21 PM
Thank you my friend. I have the conector. Will give a try
Old 09-10-2017, 08:49 AM
Works great. Just one wire in the coil. 5 turns. Tach perfect. Thank you.
Old 09-04-2020, 04:08 AM
dimtsam dimtsam is offline
Hello
I got the same issue and want to ask how the "tach" cable is connected. Just connect the single wire from plug wire to the red cable of Vapor connector? And the black one stays unconnected?
Trail Tech Vapor with goodies $45 husley Parts 0 07-28-2017 12:40 PM
Vapor trail tech jetmadgasser Parts 2 04-06-2014 12:16 PM
Vapor trail tech jetmadgasser United Kingdom 0 04-05-2014 10:08 AM
trail tech vapor for 2011 ec 300 mudwasp Enduro Product Reviews 11 05-20-2012 02:48 PM
Trail Tech Vapor DAVe3283 Enduro Product Reviews 6 03-07-2007 06:33 PM
