plugged pipe
Hi, my pipe is carbonized inside with the fumes of 2T oil. In my old CR i am simple put the pipe on fire but the GG pipe is´t painted and i can´t damage the crome.
There are some quimical way to do this? thanks
www.endurohp.eng.br Sherco ST300 2015 (Trials) https://www.instagram.com/leocm74/ Brasil! |
http://en.wikipedia.org/wiki/Caustic_soda |
We use the spray on "Easy Off" oven cleaner.
When I was a kid, we used to throw our pipes in the camp fire, to burn out the carbon, then use rocks, shook the pipe to break loose the carbon. Then dumped out rocks....That was when I rode a Hodaka
I take an old throttle cable ( just the inner cable) and make a loop, which I insert into my drill.
Then rotor rooter away, pulling in and out as I clean the inside of the pipe. |
06-07 GG OEM Pipe . Or . 07 Black Standard Pipe | gasser250sm | Enduro Engine - 2 stroke | 5 | 02-06-2009 01:07 PM |
