7MM X 1.00 Tap
Okay folks anybody here know where to get a Tap this size. I pulled my forks and rear shock and sent them to Les over at LT Racing. While loosening the tripple tree bolts I noticed that they were a bitch to break loose. Once I got the bolts out, which was not an easy chore, I noticed the aluminum had welded itself to my bolts.
When I talked to Les he told me to run a tap thru all of the bolt holes and clean them up. Problem is that I can't seem to fin that size tap. I ordered all new bolts from GoFasters and an electrician at work told me to use di electric grease when I put them back in. Seems the electricians run into the same problems we do with some of the different conduits they use. Help a Gaser Brotha out! Boom
Bikeless for Now Thanks to Smith's Powersports 724-899-3375 www.smithspowersports.com |
