2010 EC 300 engine taming mods. Which order?
Hi all,
this thread is similer to the 'six days hits too hard' thread, but not close enough to hijack or just follow that one. My ec 300 is a pussy cat in the tight stuff as is my wr250f. Both are fine for my level of talent (low). The fun and games start when I get to more open ground, the wr dosn't change as the revs rise, it just keeps pulling smoothly. As most on here know, the ec dosn't do this. The best way I can describe the difference is.. I can ride the wr for twice as long as the ec before I am wrecked. As I havn't had the ec long I am aware that some of the differences maybe set up related and not just engine. (the ec gives me arm pump, the wr dosn't) I like the light feeling the ec has over the wr. So much so that I am considering trading in the ec 300 2t for an ec 250 4t. But before I go down that road I would like to look into taming the ec with mods that will soften the overall feel and be reversable as I learn to use the power safely. So.... What I am asking is... Which of these mods that Juan knight (Davids brother) our gasgas dealer on the Island, has recomended, should I do first? I have already fitted a slow throttle. 1, Suspension set up, valved softer and lowered (the lower height is a confidence thing ~ I ride trials a lot more than anything else so rarely sit down) And the sachs are like rocks compared to the wrs. 2, Trusty adjustable power valve. Apparently this can be almost set to a flat trials like response and increased as desired. 3, squish set up and raise base gasket. Lowers compression? 4, flywheel weight. 5, gearing. I am unsure which way to go with this, I have fitted a 12t front instead of the 13t which has helped with obstacles at slower speeds. I was thinking of also going to a 50t rear which will again lower the overall top speed, but may contribute to mad accellaration when a handfull is given at the wrong time. Would a higher gearing with higher unused top speed give a softer hit at slow speeds? 6, spacer behing the reeds. This softens the hit?? If anyone has any other suggestions please add them. If I think I can get the bike to behave like my wr but without the weight penalty then I will keep her. So, which of the above (or other) mods will be the most helpfull? Cheers troops, baz
www.mrriff.com Last edited by theboogieman; 08-01-2012 at 03:30 PM. Reason: Forgot about the reed spacer mod. |
You're comparing a 250F against a 300 2T. Peak power will never ever even be close on the two. Your 300 is more like a 450F once the revs start to climb.
IMO 13/50 is good gearing. Gives you a useful 1st gear, while not making everything too short and snappy. Sometimes 13/48 is harder as its on and off the pipe more often. Squish setup will give you more power everywhere. Lowering compression will allow the engine to rev further. Raising the cylinder (more gaskets) will also favour top end power at the expense of bottom end. Removing the reed spacer will make the bike hit harder off the bottom. Ignition timing? Are you running in rain or sun mode? Jetting? Maybe switch to something like the NEDx range and run it a bit richer than ideal to produce more torque and less zing. A richer main will tame down the top end significantly too. Fly Wheel Weight, even if you have a 2k3 ignition some people here are using one and enjoying it. But in the end its all throttle control, clutch control, and ride time. If you want to avoid the hit, gear it a bit taller and change gears before it comes on song. Setting up the suspension etc will make the bike handle better and won't beat you up as much. It may help in putting the power to the ground and inspire more confidence to handle the hit. Two very different beasts. I actually own both bikes myself, and now find the 250F unexciting in comparison. It is easy to ride all day though. Last edited by Jakobi; 08-01-2012 at 06:25 PM. |
Another option is to change it to a 250 2T. I find that I can ride a 250 a lot longer than I can a 300 in the same terrain. Not a night & day difference until the end of the ride and then you realize you 'just aren't as tired' on the 250. IMO the 300 has enough torque that it works on you a bit at a time. I do love the 330 low end power and if I weren't riding hard it would be a different story. I think GMP said in another thread 'a 300 is better for trailing and the 250 is better at racing'. To each their own but the 250 lets me go faster longer
Fred Overstreet 2010 EC250 SixDays 2004 GasGas EC300 -Sold to a good home 2006 GasGas EC250-Sold to a good home 2006 GasGas TXT 280 Pro |
Flywheel weight would be my first choice. But obviously run it in rain mode. Make sure jetting is slightly rich & you could put a travel limiter in the throttle.
But where's the fun in that? |
Without a doubt the 300 was the easier bike to ride around off idle all day. If you tried to ride it hard (race it) then it would get tiring. I like to ride aggressively so much like yourself the 250 fits much better. I can sing it along carrying more revs without feeling as fatigued at the end of the trail/day. |
I very much enjoy the 300, I look at it with admiration, respect and at times awe of its capability, it truly is a bike far more capable that i aspire to be. I've been quite hushed lately as I've had very little to pass along as your complaint listed has hurt me so often I cannot go into them all, currently my left wrist is recovering well, and I have close to full strength back and I am being quite easy on it as I have prepaid for my Shane Watts school in Oct, a exciting opportunity I have been wishing for for longer than I can even recall. I went to a local hard track and had some other old farts watch me, my decades of riding my 200 led to some very predictable habits, none were truly in bad riding form, but did not account in any form for the power valve or extreme horsepower this bike has compared to my 200. I found I was very very consistently rolling into the power before the apex of the curve, which on a predictable non power valve 200 and proper weight transfer on a machine of evolution linkage design led to a loose rear end and some nice speed through the apex with an agressively fast exit speed compared to my competition, on this machine merely squatted her ass, lightened the front end and of course, blew my front end out putting me down time and time again. hey!! at least I figured it out. I chose to post here mainly to empathize with your concern and tell you truthfully, a flywheel weight will do everything you want within the limits of what is possible, I also have the larger pv cover, although it yeilded no discernable difference, perhaps cumulatively, the weight, pv cover and what i deem as a "fat" midrange transition across the carb has mellowed this machine out as much as possible. The rest, is up to me to relearn some ingrained riding styles and of course to back off a bit on my aggressiveness and start focusing on riding more my age......:-) |
More good info re riding style. Particularly the getting on the throttle in corners. Making the move from 250F to 300T this was super super noticable. I was always rolling the 250F on before the apex and WOT as I'd exit a turn. Do this on the 300 and it just hooks up and you come out on the back wheel, or it breaks traction and launches you in another direction.
Having ridden both (and I'm not very good), I am astonished at all this 300 fear. My biggest concern is that the 300 will feel too docile (read "unexciting") compared to my pipey and modded DE250.
However, we are comparing a 300T to a 250F. Not even so much a comparison. The OP just wanted to know ways to tame the 300 down and make it a bit smoother. I think there's pleanty of useful information on how to mellow the bike, but a certain element of it is also held in the riding technique. |
Thanks for the great info guys,
Gives me a lot to have a think about. To clarify, I don't have 'problems' with the 300 and am not scared of it (well, ok a bit, hahah) Also I'm not coming 'from' the 250f to the 300t, I got both earlier this year and will still be using them back to back for the rest of the year. Both are still new to me. At the start of the year, I got back into 'enduro' bikes as I had got back into trials a couple of years ago. The remit was to pick up and try out a few differing bikes to find something that suited me. I'm nearly 50 so know my limits and am looking to find a newish bike I can see out my riding time on. (hopefully awhile yet). The 250f motor has so far impressed me with it's electric style power delivery. the 300 i like for the handling and lightness. I've had to bench press both of them a few times and it's a no contest win for the 300. Both are great in tight sections (my favoured playground, the fast stuff is not a happy place for me) My original post was to see if the best of both worlds could be had by smoothing out the 300 to a more electric style also. Before I discounted it and carried on looking. I have noticed that whilst it is cool to lug the 300 around in a gear higher, it never feels happy. when it is on the pipe and singing it digs in and rides fantasticly. Unfortunately everything is happening far too quickly for me by then. It may be that descretion is the better part of valour, and I accept that the 300 is too much bike for my needs. Maybe have a look at, as suggested, a 200 2t. I am still considering getting a new wr250f or a gg250f, but both are still quite heavy. If anyone has any ideas on other makes or other gg models that might be better suited? May end up putting a big tank, hand gaurds and lights on the txt pro yet.
www.mrriff.com Last edited by theboogieman; 08-02-2012 at 06:55 AM. Reason: Spelling |
taming it down | dank | Enduro Engine - 2 stroke | 23 | 06-04-2018 05:40 PM |
New 2010 EC300 Engine Noise (falling revs) | Jakobi | Enduro Engine - 2 stroke | 11 | 11-16-2010 06:41 PM |
Swingarm installation order? | Trailrider | Enduro Chassis & Body | 2 | 06-18-2009 11:08 AM |
EC 250 engine mods | DLS | Enduro Engine - 2 stroke | 14 | 06-03-2009 07:19 AM |
Where order shims | borsiin | Enduro Suspension | 5 | 12-10-2008 04:45 AM |
