Go Back   Rieju & GasGas Legacy Riders Club Forum > Classified Advertisements > "Wanted to Buy" & "Want To Trade"
"Wanted to Buy" & "Want To Trade" Bikes or Parts
Old 08-06-2016, 02:34 PM
GGRider01 GGRider01 is offline
Default Cdi
Old 08-06-2016, 05:58 PM
I have one for 2011 250.
$60?
Old 08-07-2016, 09:09 AM
You can use the new one on the old bike but you will also need the new bike harness with the CDI electrical connector plug because the older bikes had individual connectors for each of the wires. You can buy the GG harness or you can build one if you are handy with schematics and wiring. I built a conversion harness using a KTM harness off ebay. When you finish it is cool to have the dual map CDI.
Old 08-07-2016, 12:33 PM
When I bought the stator from mcc in Spain I got the adapter for the new CDIs.
Correct me if I'm wrong but the dual map CDIs can be put in sun mode by connecting the 2 wires together that usually run to the map switch, right?
Old 08-07-2016, 01:12 PM
I do not recall if open or closed circuit puts it in sunny mode.
Old 08-07-2016, 01:22 PM
Anders Anders is offline
Yes I am quite sure a closed circuit is sun mode.
Sent fra min GT-I9295 via Tapatalk
Old 08-07-2016, 01:49 PM
I sent you a PM gasgasman.
BTW, part number for the adapter, for the less patient of us, is ME250534017.
