#11
Buy 43 x 3.5 Viton o-rings. They seal better and last longer.
Installation can be difficult, especially if your pipe has been bent. First off, don't put grease inside the o-ring groove or the o-ring tends to pop out of the groove during installation. Just grease the outside of the o-ring after you put it in the flange groove and grease the inside of the pipe flange. Then push the pipe on far enough to get the springs on and let the springs pull it up.
Eric K '06 GasGas EC300 '01 GasGas XC300 |
#12
My 12 300 had issues. The springs were not very tight and would rattle to be... So I took a piece of copper and machined an .125" spacer to go between the pipe and the flange on the cylinder. Worked great. No more rattle.
#13
So will try to bend it out this evening and failing that i may try the spacer option to solve 2 problems in one go! SteveV , to clarify, this spacer you made does it fit on the end of the manifold, inside the exhaust?
#14
here is a of what I machined. .125" thickness seemed to work for me.
High pitch Squealing from exhaust and exhaust flange????? | Scar13 | Enduro Engine - 2 stroke | 5 | 02-11-2012 11:32 AM |
rattle | Rabbitist | General Discussions & Announcements | 4 | 09-07-2011 08:10 PM |
200 powervalve rattle? | noobi | Enduro Engine - 2 stroke | 3 | 04-08-2010 07:25 AM |
pipe rattle | redrider7202 | General Discussions & Announcements | 5 | 04-06-2010 07:33 AM |
clutch rattle? | jostby | Enduro Engine - 2 stroke | 0 | 02-25-2007 05:01 PM |
