2009 SACHS Shock Question
Hey guys, I am second guessing my manual for the 2009 EC here. The section regarding the shock high and low speed adjusters, the manual states the high speed adjuster is the small inner screw and the larger outer adjuster ring is the low speed. To me this seems backwards, from KAYABA, SHOWA, and WP shocks. Is the manual wrong in this case? This could cause big headaches when suspension tuning!
I am second guessing the manual because in the engine break-in section, it tells you to add the recommended amount of coolant AFTER 2 heat cycles have been performed. Also in the middle of that somewhere it tells you install parts removed; it never tells you to remove any parts!! Silly Spaniards!!
2009 GasGas EC300
2008 KTM 300XC - Sold
2004 KTM 450SX - Sold
