#11
Cheers mate,
Well we finally removed the race. It took me grinding two opposite sides and welding a tag on each remaining side and a bearing puller to remove it , but all looks good. I reckon the shaft has been heated on practically every side , one way or another so hopefully we'll be ok, what do ya reckon? About to go get bearings tomorrow and could do with some info if anyone has the info. Cheers Mark |
#12
As I am in a rush and cannot afford the time to wait for a roller type bearing for the left side crank bearing we are going to use two caged ball bearings and then rebuild the whole lot( big end , rod , piston etc when I get back from the week away.
Will this be ok as the 2000 models used to used a rcaged roller each side didn't they. Cheers Mark |
Ignition side crank bearing failure? | wence | Enduro Engine - 2 stroke | 37 | 06-16-2016 07:21 PM |
03 EC300 crank bearing problem | bwalker98 | Enduro Engine - 2 stroke | 4 | 05-04-2010 05:05 PM |
Trailtech location urgent.... | wence | General Discussions & Announcements | 0 | 01-04-2010 04:06 AM |
Urgent Gunnison Petition. | Ud_luz | General Discussions & Announcements | 8 | 06-03-2009 07:55 AM |
2007 EC250 Crank Bearing? | BIG TOOL | Enduro Engine - 2 stroke | 9 | 11-23-2007 02:47 AM |
