Old 09-20-2014, 02:40 AM
2taddict 2taddict is offline
Default Derestricting 2006 EC300
I have just bought my first ever Gas Gas. A immaculate 2006 EC300 which has only been used by a novice for trail riding.
I have heard that these bikes stock are somewhat restricted for road use and I want to open it up for some enduro events.
What needle do I need @ sea level ?
What a good exhaust system to get it breathing ?
What's this reed valve mod ?
Is the airbox restricted ?
All help appreciated.
Old 09-20-2014, 03:52 PM
gasmonkey's Avatar
Bronze Level Site Supporter
I had one of them.Good solid honest machine.
Needle----n3eg to really make it buzz or jd blue for smoother ride.Standard n1ef etc are way too fat and makes them bog down.Check float level.
Exhaust should be fine unless you have the black road version fitted.If it is,ditch it.
Reedvalve is ok standard.
Air box ok, but check there's no road restricter plate behind the airfilter.
Treated right these girls will give many many hours of riding goodness.
Old 09-21-2014, 04:25 PM
Got it...thanks for the reply.
It has silver expansion chamber with FMF muffler so I'll just order a jet and check out the airfilter....easy as.
Cheers.
Old 09-21-2014, 07:49 PM
jimjim jimjim is offline
If your looking for cheap power,get your jug ported.
Old 09-23-2014, 04:47 PM
Thanks guys I'll try a n3eg.
Maybe do porting down the track if needed cheers!
2006 ec300 MichaelG Used Bikes 2 08-14-2013 07:07 AM
2006 ec300 top end splutter motopsycho87 Enduro Engine - 2 stroke 7 07-04-2013 06:48 AM
2006 EC300 problem fury1 Enduro Engine - 2 stroke 29 06-09-2009 05:40 PM
