Old 04-01-2021, 11:00 AM
steliost's Avatar
steliost steliost is offline
Default DIY billet clutch cover
The clutch cover on the EC250 started weeping from where it was already welded and I put some Mannol cold steel epoxy there but it did not convince me enough... On the search for a new cover I found out they are pretty scarce and expensive.
So I decided I would try to make one out of a fat slice of aluminum on the lathe and mill. Fun! A bit less than 25 euros of material and 3-4 hours of work, with breaks, and here we are. I had to cut off the excess material around the flange with a handheld grinder since my milling machine is quite old and does not support such intricate cuts, and that was the most time consuming and boring part of the operation. Not much fun. aluminum dust all over the place.
I left 1mm more room on the inside for the clutch and went about double the thickness on the face for extra durability, the stock is only 4 mm and caves in like that! I know it's a bit rough around the edges and heavier but ehh... saved us a 100 euros at least and the hassle of searching all around the interwebs.
Old 04-01-2021, 11:27 AM
Neil E. Neil E. is offline
Nicely done! It sure is great to have access to machine tools.
Old 04-01-2021, 11:52 AM
steliost's Avatar
Sure is, bud! cheers
Old 04-01-2021, 02:54 PM
That's cool. Now here's my gift to you. I also have a blue anodized yz kick lever.
Gell oven cleaner. Wipe on, brush, wipe off. Repeat twice. Perfect.
Old 04-06-2021, 02:45 AM
Anders Anders is offline
Nice work! I have have had similar thoughts, but ended up with buying Rekluse covers.
Old 04-06-2021, 03:01 AM
steliost's Avatar
Thank you gentlemen! F5 nice tip, will do it next time i'll have it off the bike. Anders that was our first thought also but they were mostly out of stock and around 150 euros. Not that the bike is not worth it but since i had the means to do it and had the OK from the actual owner i tried it and it seems like a good choice so far. And that satisfaction of doing something useful with your own hands is the cherry on top!
Old 04-06-2021, 05:01 AM
Indeed! I have a lathe (old Harrison) and a small mill. I make some motorcycle parts myself, as well as tools for maintaining the bikes.
I also do some wood work. Right now, my main project is refurbishing an old workshop (inherited from my dad and uncle). It is approx 100m2, with garage / workshop at ground level and a woodworking shop at the first floor. It stood with a leaky roof for years, now I have to replace parts of the wooden constructions due to lots of rotten wood. I did the roof some years ago, now it's the rest. Will take me a couple of years, I think.
Old 04-06-2021, 07:41 AM
steliost's Avatar
I also got the tools and the shop passed on to me from my father when he retired, as he had from his father. I am a machinist by trade like both of them, grew up in the shop practically and I enjoy working in that environment! I've got two lathes, a mill, a 50 ton press, a couple of column drills, two welding machines (MIG and stick) and a bunch of hand tools, taps etc. Mill, lathes and the big drill are Czechoslovakian and Polish made, very sturdy. they used to work non-stop back in the day...
Success in your endeavor, mate!
Old 04-06-2021, 11:20 AM
Years ago machinists who knew the value of sturdy machines always bought Czech machine tools. We have them at work and they are still going strong after at least 40 years.
Old 04-06-2021, 01:03 PM
steliost's Avatar
Yes, so true. every old machine shop, at least around here has a czech piece of machinery still working with great precision. they have returned their value in money many times.
Clutch cover adv rider Enduro Engine - 2 stroke 7 07-29-2016 10:33 AM
Clutch cover Buysomerice "Wanted to Buy" & "Want To Trade" 1 11-24-2014 06:29 AM
Clutch cover ? biggstr6 Enduro Engine - 2 stroke 9 03-20-2012 09:58 PM
Gas Gas billet clutch baskets mxdj2003 Enduro Engine - 2 stroke 6 11-03-2009 09:28 AM
