Old 04-19-2015, 05:13 PM
RockefellerGG RockefellerGG is offline
With an angle grinder, drill, and $1 worth of steel from my scrap bin, I'd be much more inclined to just make a tab.
That YZ bracket appears to be cast. I've never had good luck welding cast parts to cold-rolled. Depending on what filler rod your welder used, you may get decent results.
Glad you've got it back together!
Old 04-19-2015, 08:50 PM
Wimpy525 Wimpy525 is offline
Bracket is not cast but it was galvanized.
Old 04-19-2015, 09:08 PM
Using the YZ bracket takes the "guess" work of where to drill the foot peg pin hole.
Old 05-29-2017, 05:57 PM
mtnmanseth's Avatar
mtnmanseth mtnmanseth is offline
Clipped a rock HARD today during a technical climb and broke my left side foot peg off. It sheared the pin completely and damaged the frame as shown. My foot's fine... pulled it up anticipating the hit.
Do you guys recommend I replace the whole mount with the one from the YZ? Grind it down flat and have the YZ mount welded on? Or do you think the existing tabs can be bent back and potentially spot welded (cover the cracks) and keep the strength I need? Definitely don't want to worry about a peg breaking off unexpectedly
Also, where the heck do I get a replacement pin? Is it a special GG part? Or are they standard across all bikes? I'm replacing pegs with Tusk billet for YZs off Rocky Mountain ATV.
2005 GasGas EC300
2017 Beta 300RR Race Edition
2021 TM Racing 300EN Fi (2T)
Old 05-29-2017, 06:45 PM
Looks like you can bend the tab down and weld the bottom side.
The YZ pin should fit.
Old 05-31-2017, 10:59 AM
mtnmanseth's Avatar
Do you mean bend the top tab back? Will this weaken the metal? Should I have a bead of weld put into the inside seam against the frame for strength? The top photo shows where the paint has cracked at the bottom tab... should I grind that off and add some weld in there too?
2005 GasGas EC300
Old 05-31-2017, 11:47 AM
Yes. Do as you described.
Old 05-31-2017, 01:12 PM
mtnmanseth's Avatar
Will do, thank you sir
2005 GasGas EC300
Snapped frame on wild 300 case-racing Other GasGas Bikes/Quads 7 09-13-2020 03:17 AM
snapped a pinch bolt thejackrabbit Enduro Suspension 2 03-30-2014 05:38 PM
2012 snapped subframe Poncho General Discussions & Announcements 21 09-14-2012 12:44 PM
Snapped bars coolum74 General Discussions & Announcements 2 03-29-2009 02:35 PM
Snapped valves on 02 400 douglase1983 Enduro Engine 4 stroke (including EFI & Exhaust) 3 01-10-2009 01:33 PM
