Oversize powervalve cover.
Have just bought a oversized powervalve cover and was wondering do you plug the middle threaded hole that looks like it goes through to the barrel? or leave it open?
Bike is a 02 300.
02 300ec- 50mm Marzocchi cc forks, 2010 plastic. Now a 250cc. |
should be bolted,the stock one also is bolted in the same spot
Ta, thought it should be but thought it would be better to ask rather than just blindly do it.
power valve cover
what does an oversized cover do ?
Theory is it increases your bottom end power by increasing your volume of the power valve chamber. In other words gives a bit better throttle response down low. Good for real technical riding.
I put a Trusty cover on mine. Not really sure if it's needed on a 300 but the damn thing won't stall now.
HuskyDude 10 EC300XC 08 TE510 07 TXT 280 77 TY175 |
I'm not a fan. Dulls your low end throttle response but fattens the torque a bit, great for guys with less than perfect clutch ,throttle control or who dont like crisp zippy power.
Power Valve cover
The hole should be plugged or preferably a drain line attached. I used a zerk fitting with the center drilled out and added some tubing.
Dulls? nope,, adds bottom end by adding volume that becomes a non issue once the pv opens. Never heard of it dulling the bike down.. gives it more grunt. odd you say that.. On my 03 it was needed,, the 03 was very weak off the bottom,, I did the big cover, messico pipe and a cdi from an 01 300xc and it was good. Oh, and ltr jett and special reeds I got directly from the boysen shop down the road.
Steve 16 Beta 350rr 04 KTM 525 sx/exc gone 03 KTM 625 sxc-rehab unit-did its job and now gone 03 GG 250 ec-gone 97 GG 250 ec Gone |
Some oversize covers don't have the center bolt like the OEM one.
In this case, leave the bolt out. |
Adjustable powervalve cover | darren | Enduro Engine - 2 stroke | 1 | 01-12-2009 05:27 PM |
ltr powervalve cover | moff747 | Enduro Engine - 2 stroke | 5 | 03-05-2008 01:24 PM |
'03 200 Powervalve cover | Bearman | General Discussions & Announcements | 9 | 01-01-2008 06:59 PM |
LTR powervalve cover | ejas | General Discussions & Announcements | 2 | 08-23-2007 08:09 AM |
Rejet for LTR Powervalve Cover? | SpeedyManiac | Enduro Engine - 2 stroke | 7 | 05-11-2007 11:37 PM |
