final drive sprocket seal
I have found the seal behind my drive sprocket is leaking, is it easy to change or am I looking at a big strip down.
Easy, comes out from the outside with a seal puller or hook once the sleeve is removed from the shaft. An o-ring also seals the rear of the sleeve. If you see oil coming from between the shaft and sleeve this is the problem, not the seal. Its a good idea to replace all three.
Cheers for that GMP.
Final drive seal? | nick790 | Enduro Engine - 2 stroke | 2 | 10-14-2009 03:37 PM |
Steel Drive Plates | nr1strange | Enduro Engine - 2 stroke | 1 | 08-11-2008 09:41 AM |
Final drive chain | anathema | Enduro Engine 4 stroke (including EFI & Exhaust) | 3 | 04-14-2008 08:44 PM |
Counter shaft Sprocket Seal | Rick | Enduro Engine - 2 stroke | 4 | 12-03-2007 09:00 AM |
