Header tank level ...
2004 300ec , is there surpose to be any coolant in there ? i did a day out last sunday and it was warm so i checked the coolant last night and i had to add a cup full.
I can only think it was fired out the overflow so what im a asking is is there got to be any coolant in the small curved header tank around the front of the frame ? |
no, it is just an expansion tank, not a reservoir.
with your bike being a 2003 it may help to just replace your radiator cap with a new one. I know a few have removed the expansion tank altogether and fitted 1.8 cap
sorry 2004
Mine (2005 EC250) will hold a little coolant in the header when warm, maybe a level of 10-15mm. As said check the rad cap, they can leak due to dirt under seals and or rubber wears out.
Andy |
Is it time for a logo/header refreshment? | stabak | Suggestion Box | 3 | 01-24-2013 10:16 AM |
Will the 03-05 header work on an 01? | forgiven | Enduro Engine - 2 stroke | 8 | 02-09-2011 04:23 PM |
PN double header - roll call | SpeedyManiac | Off Road Racer's Corner | 2 | 05-16-2008 05:32 PM |
