200 EC Electrical probs.
Hello, looking for any advice on the 02 200 GG , i ran it this past week end, had a constant miss i thought was lean jetting, well this got worse through the day, finally bogged out and quit, i had thought maybe a fouled plug, but i changed the almost impossible to do with a reg wrench, and started up, runs untill it gets hot then dies out, am i looking at a coil? stator assy?
and does anyone out there have either of these used, or is there an upgrade?? thanks all
Shutup and Ride !!!!! |
My 2001 SE250 was doing the same thing.
Turned out to be an ignition coil. Couple things to check also. Gas cap vent. Kill switch. Be sure the plug boot is screwed on tightly to the coil wire. You can always cut a 1/2" off the wire and screw the plug boot back on. |
reply
Thanks, do i need to buy a genuine gas gas coil or will one retro fit??
my cap didnt have a line on it, will have to check that, also is it often these bikes are noted to collect water or moisture in the stator area? mine has been siliconed from hell, so just want to make sure got all bases covered thanks
I have a coil you could buy/try. The stator cover should be removed after every wash to let it dry out.
coil
how much are you looking for, on the coil?
shipped to 60050
At the very least get the motor up to full operating temps after washing the bike if you choose not to pull the cover (this should be done anyway if possible) |
thanks skidad, i know thats what i should do, i guess laziness is to blame, i really do feel it is a coil, but the way this was siliconed up , i would even think O Bama could infiltrate it with spam!!!
but will be pulling it apart tonight and checking it all, i also have a coil tester at the shop, i will cook it for a bit see what happens........... Thanks guys for all the quick tips and info
300 probs????? help?? | wence | Enduro Engine - 2 stroke | 12 | 09-01-2010 10:20 PM |
07 ec 300 speedo probs !!! | pilktm | General Discussions & Announcements | 3 | 02-08-2009 12:50 PM |
Idle probs, can't seem tp resolve.. Help! | RichyN | Enduro Intake/Carburetion - 2 stroke | 18 | 12-14-2008 07:09 AM |
probs with 04 ec250 shock | smithys ec250 | United Kingdom | 4 | 02-07-2008 05:06 PM |
Kick starter probs | peterr | Enduro Engine - 2 stroke | 4 | 10-03-2007 05:36 AM |
