has any one looked at making the non powervalve governor adjustable
looking at the 018 set up it looks possible
I guess it would be possibly. Buy, would be expensive.
You can adjust the earlier power valves, through the internal shims. |
the 015 on. adjustable shaft is only ?15 if it fits all iv got to do make a cap/nut and drill tap out the clutch cover.got a used 98 pv governor of ebay to play with.any one got a 015 on pv gov to hand they can measure the shaft need diameter length slot position / length of slot thanks
Adjustable powervalve anyone? | jt633 | Enduro Engine - 2 stroke | 1 | 01-28-2014 09:30 PM |
Trusty adjustable powervalve cover ? | 101racing | Enduro Engine - 2 stroke | 5 | 06-03-2009 12:14 PM |
Adjustable powervalve cover | darren | Enduro Engine - 2 stroke | 1 | 01-12-2009 05:27 PM |
