Go Back   Rieju & GasGas Legacy Riders Club Forum > General Forums > Riding Techniques & Training
Riding Techniques & Training Increase Riding Skill, Physical and Mental Training, Weight Loss.
Old 09-24-2013, 01:42 PM
Garytee's Avatar
Garytee Garytee is offline
2 fingers on clutch & index finger only on the brake for me. More habit than anything else really.
2004 EC 200
2004 EC200
Old 09-24-2013, 04:12 PM
bazzagas bazzagas is offline
Index finger on the clutch at all times and either 1 or 2 on the brake depending on how hard I need to apply them. As another member said, adjust your levers correctly, it will make a big difference.
Old 10-28-2013, 04:11 PM
Caravan Monster's Avatar
Originally Posted by eviljim View Post
I am trying to improve my riding, so I a practicing the double blip to get over loges etc. I am finding that if if use two fingers on the clutch then I don't hold the bars at I would like, but if use one my arm gets tired. What do you all do? One or two?
Do you need the clutch for double blip ? Throttle, approach speed and weight transfer should be enough to get over most logs. Difficult bit is timing the second blip right. One finger on the clutch when I expect to use it.
'00 Montesa Cota 315R
'13 Husaberg TE 300
Old 10-28-2013, 06:57 PM
Minimum of one finger on the clutch always.
Anyone who hops a log without a finger or two covering it is just waiting to throw it away. When things go pear shaped its usually the clutch that stops all that engergy from driving the bike away from you.
Old 10-29-2013, 05:53 AM
sevenfourate's Avatar
sevenfourate sevenfourate is offline
Thats infornative for me at least ! Another tip for the memory banks........
For what its worth (And harking back to years of freestyle BMX - and using stubby DiaCompe 2-finger levers ive always ridden motorbikes with 2-fingers on each lever.
Regards Shuv - 2006 EC 250
Old 11-03-2013, 02:59 PM
Always put your levers parallel with the ground, never lower, you will get terrible pump.
Try this, twist your wrist down so your thumb tried to contact the underside of your forearm, now clench a fist.
Now bend your hand back and do the same.
And the answer to the question, start with 1, then 2... any more and you shouldn't be riding her.
2016 RM-Z450
Old 11-03-2013, 04:48 PM
eviljim eviljim is offline
No way! My levers are set to my arms. I don't get pump I am quite light on the bars. But I am so out of shape, if I am using one finger all the time my arm does get tired.
Anyway, I seem to use a mix of two and one. I need to get fitter.
Old 11-04-2013, 12:10 PM
From my cycling days, i was taught that the levers should follow, and continue the line of your forearms in the 'normal' riding position.....
Thats how i always set my levers up, bar the fact i always have the front brake lever slightly more upright than the clutch as its always felt 'comfier'.
Old 01-07-2015, 08:46 PM
95jersey 95jersey is offline
Went to an enduro school with a national champion. The advice was one finger on both and levers in the downward position. I use my middle. You will eventually build strength and by using the middle I mantain the best grip on the bars. It is tricky with a cable pull clutch.
Old 01-08-2015, 05:44 AM
Dirt Dud's Avatar
Dirt Dud Dirt Dud is offline
One finger on each when I have an nasty chunk of wood or a slippery rock . Otherwise my recluse 3.0 saves my arms .
IF I HAD ALL THE MONEY I SPENT ON DIRT BIKES , I WOULD SPEND IT ON DIRT BIKES
