Enduro Product Reviews Feedback & Comments on Products Tested |
#11
By the way these fit 01' on up according to the website. Just mounted up a set on my sons 02' 250. I'm impressed,these scorpions are burly! Only issue was not much daylight between exhaust pipe and lower right radiator guard,bench grinder took care of that. Havent mounted mine yet on the 05' 300 but eyeballing it there is much more room on the 05 tween pipe and radiator. Much beefier than the crd's I;ve straightened numorous times and are now broke.
I also removed lower grommet and used supplied bolt directly into threaded hole in guard per instructions-cinched right up.than I tightened the two upper mounts in tank. They all lined up as well as they usually do.
TeamFlannelOutdoors-somewhere South of I80 05' Gas Gas 300 DE (Son's) 22' Rieju MR300 80th Anniversary Edition. 02' Gas Gas 250 XC Moto Farm motor and suspension service 309 310 2540 leave a message www.halls-cycles.com |
#12
I also took note of the small clearance between the Scorpions and the pipe. I have about 1/2" between my P3 guard and the outer bracket. I'm thinking it will be fine since the guard is there. Scorpion could probably have left a bit off the bottom of the guard and still been fine.
I ended up using a 1/4" nylon spacer on my bottom shroud bolts after installing the Scorpions. It was the perfect size, allowing me to torque the bolt down and not kink the shroud.
2011 Gas Gas EC300 38mm, 2008 Husky TE610, 2003 Beta Rev3 250 |
#13
I know it doesn't look quite as good but I use a zip tie to secure the bottom of the shrouds that way when they get caught on something the shroud doesn't get damaged.
#14
reviews???
Anyone else dropped their bike and stayed damage free??/
I need new braces, whatever brand is on my 250 bent today on light impact I crashed alot today ,,,,,,,,,,,,,, I like the look of these they look tough So any other thumbs up? |
#15
Yes they are tough, they fit great, they install easy and are priced well. Solid stuff
Question on frames. | HuskyDude | General Discussions & Announcements | 9 | 10-18-2014 11:28 PM |
Racing start - dead engine tips please | stay_upright | Enduro Engine - 2 stroke | 12 | 04-19-2011 04:47 AM |
Scorpion Rad Frames-2010/11 EC-Install Pics | JP4 | Enduro Chassis & Body | 4 | 02-07-2011 07:33 AM |
Scorpion Racing Radiator Frames and Skid Plates | Kurdt | Enduro Chassis & Body | 8 | 08-16-2010 05:30 PM |
Anyone installed Scorpion Racing Radiator cages on a 2010 model? | Kurdt | General Discussions & Announcements | 6 | 08-11-2010 06:26 AM |
