Old 12-02-2012, 06:17 PM
shark4465 shark4465 is offline
Default 12 300 running strange
it started 2 weeks ago when riding in the whoops the bike bogs then it sounds like it hits the powerband but its not the bike never stops running on flat ground it seems normal
Old 12-02-2012, 07:53 PM
pscook's Avatar
pscook pscook is offline
Float height is the probable culprit. It might be too high and fuel keeps sloshing at the wrong time. Drop it a mm or two and see how it does, if there is no change (or it's worse), then go the other way.
Phil
(New bike pending...)
Old 12-03-2012, 05:02 AM
i will try that first
Old 12-08-2012, 05:29 PM
knovello's Avatar
knovello knovello is offline
Same exact thing happened to my 2012 300. The float height came out of wack after 4 months of riding/racing. Adjust back to factory spec and you should be good to go.
2012 GG 300 Race
Old 12-24-2012, 05:40 AM
well i adjusted the float did't change a thing talked to clay he said power valave rod is rubbing there was alot of play in the rod so i adjusted it rode it yesterday still the same i think i may move on to other bike
Old 12-24-2012, 05:53 AM
hannesd hannesd is offline
why would you move to another bike if this might just be a simple sollution?
Old 12-24-2012, 04:08 PM
running out of things to check the bike is less then a year old just getting aggravated
Old 12-25-2012, 07:12 AM
hamilton's Avatar
hamilton hamilton is offline
Just a thought try removing gas cap vent line check valve.
Old 12-25-2012, 09:36 AM
fletchman45 fletchman45 is offline
This stuff is exactly why I have ALWAYS been cautious about buying a Gas Gas. But yet my 05 has NEVER had any problems and has Always been say Honda reliable. Every Husqvarna I have bought has been bullet proof. My new Gasser lost the gas tank bolt in less then 30 minutes of ride time. A fluke I hope. It must be something simple as to my knowledge that 300 engine is pretty darn bullet proof. And if Steve and Jay say they are just as reliable as a Husky then it should be. Keep us posted. I won't even get to ride mine until spring (new 12 300) But for the 30 minutes I rode it I will say the Ergos felt sweet the engine is electric and if it holds together I am confident I will be able to ride it fast. Did not feel like it weighs 250 pounds riding it or pushing it around. Not to tall either. Vent seems like it could be. Let us know. All bikes can have a little gremlin. Sounds pretty simple. Ignition or carb? I have NEVER had to adjust the carb float height in 20 plus years of riding so not sure why that carb would be different. I would try to fix it. That bike looks better then anything on the market and has high quality componets thru out the bike. Something minor I am sure!! Any good dealers nearby??
Old 12-25-2012, 10:17 AM
i also lost my tank bolt i also had the tank crack they replaced it for free i may just have a lemon it's not the vent it's something in the power valve
Rather strange problem on the 11 300 six days bukwheat General Discussions & Announcements 7 04-15-2011 03:08 PM
Strange electrical problem GMP Enduro Electrical & Wiring 14 12-14-2010 08:25 AM
06 EC300 - strange sound when over revved colinmc400 Enduro Intake/Carburetion - 2 stroke 5 05-02-2008 12:10 PM
Strange air leak in ignition cavity d2w Enduro Engine - 2 stroke 4 02-14-2008 01:34 PM
No wonder my forks felt strange JCW Enduro Suspension 2 12-01-2007 04:45 PM
