#11
Testing the stator and pickup coil wiring to the cdi should be fairly simple. Then from sparkplug to cdi. Also remove kill switch.
#12
coil is fine as its new, stator is fine as been tested with a multi metre, swapped cdi form a friends bike and fired up 2nd kick, rang every trials bike dealer or breaker in the space of a week and unable to get me a new or used one any where. the bike is in pristene condition and im cutting my losses and breaking for parts.
#13
Before you throw in the towel, you might want to try one thing. Can't hurt.
Around 2010, i decided to build my own ignition for my EC300. (Long story.) Anyway, l learned quite a bit about CDI ignitions, and from that, i offer something inexpensive to try. For $25US, you can buy a CDI for a Honda CRF 50. Please see https://www.crf50.com/trail-bikes-cd...rf50-xr50.html It wires up just like a "normal" cdi found on a two-stroke dirt bike. The advance curve might be a bit off, but at least you can make your bike run. it just might run well enough that you'll keep your bike. I've attached the honda 50 wiring diagram which you can use as a reference. Please let me know if you have questions. UPDATE: I am curious, so i am ordering one of these: https://www.ebay.com/itm/Performance....c100677.m4598 I will get this running on my EC300 (shelter in place project) and let you know how it goes. The documentation here seems a bit better. Last edited by blitz11; 03-28-2020 at 07:34 AM. Reason: spelling |
#14
So, i ordered the CRF 50 $15 ignition. of course, things never go as well as you hope, but I was able to make it work.
I used my (spare) Kukosan ignition as my reference. I have a Taig lathe, so i can run the ignition up to about 5K RPM. (I can go 11K with my mill, but i don't think that i need it for this). Anyway, i measured the advance of the CRF 50 ignition and i compared to the stock ignition on my GG ec300. Low speed and high speed advance are about the same! I used my timing light, and both advance zones are within a degree of each other. I don't know how the trials bikes are, but combustion is combustion, so it would probably work just fine. Anyway, if you find yourself with a dead CDI, you can fix it for $15. I haven't put this on the bike yet because it's still cold and snowy. If i have time, i'll mount it to the bike and see how it works. It seems fine on the bench. |
#15
just wanted to say i finally got a cdi from australia, i rewired the bike with fresh cable and leads and chopped out all the unnecessary things i.e lights and horn wires that arent connected and one all put back together it fired straight up first kick.
#16
I am glad that your bike is running. |
Tags |
280, gasgas, txt |
Thread Tools | |
Display Modes | |
gasgas ec300 05 model wont hit full powerband??!?!?!? | jimmyT | Enduro Engine - 2 stroke | 9 | 08-30-2011 11:31 PM |
EC200 kick start lever (2000 model) | sireid | Enduro Chassis & Body | 11 | 01-24-2010 02:56 AM |
02 EC 300 wont start | GENO 300 | Enduro Engine - 2 stroke | 0 | 09-21-2009 10:02 PM |
wont start | clerky clerk | Enduro Engine - 2 stroke | 8 | 11-01-2008 01:18 PM |
2000 Xc 250 wont start In mesa arizona | justinmanus | Enduro Engine - 2 stroke | 9 | 12-25-2006 04:46 AM |
